OctaneRender® for 3ds max® v2019.1.5 - 8.19
neonZorglub
Elvissuperstar007 wrote:Bug Sun
video
Hi Elvissuperstar007,
Thanks for reporting this problem.
The Quick mode is now incorrectly using only the environment map / color..
You can disable the Quick mode when using daylight environment, or use the previous release..
This will be fixed in the next release.
Elvissuperstar007
alpha channel does not work on glasses
paride4331
Elvissuperstar007 wrote:VrayCarPainMtl not converted
Car paint material here.
carpaint.orbx
(67.47 KiB) Downloaded 275 times
paride4331
Elvissuperstar007 wrote:alpha channel does not work on glasses
you would check alpha channel in Kernel panel too.
Saving your render don't forget to use alpha channel embedded file (.png, .tiff, .exr...)
nildoe
The PLANE object is not rendered if I want to render out a sequence in max!!!!
when u open the octane render window the plane is not shown, u have to press rebuild scene for it to appear... but whatever i do..when i render out a SEQUENCE the plane does not show... REALLY GUYS??? A PLANE??
Max2018 and octane 8.19
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
paride4331
nildoe wrote:The PLANE object is not rendered if I want to render out a sequence in max!!!!
Hi nildoe,
I tried unsuccessfully to replicate your issue.
Could you share a sample file and some screenshot about this.
nildoe
Upon first opening the scene i get this..if I re-open it (without saving) and render..it renders :(
I can't share the scene file...its too big and my internet is very slow... whats weird is that when the plane btw its not just a plane..if I make a new simple box (in this scene its a box since the plane was not working)..at first it seemed to work..but even with the box sometimes it renders sometimes not..
Edit: I really DON'T understand what's happening..if i ISOLATE the plane and render..it renders...it seems to be a random bug.. if I unhide allprevious hidden objects by isolate and render the sequence all renders fine.... I even tried merging the scene to a new max file..it happens all the same.
Edit2: I'm getting this issue even with 8.18 :(, and it seems that if I select the plane and all the other objects in the scene and render its renders fine..but i have yet to confirm this...
paride4331
Hi nildoe,
thanks, could you
Could you share a video while running into the issue?
nildoe
Hi Paride..
here is the video attached.. its using 8.18, but the same happens in 8.19
using an RTX2070 441.28 on windows 10 on an MSI laptop ge75 raider 9sf (64G RAM, 5TBHDD)
Plane Issue.mp4
(7.75 MiB) Downloaded 3484 times
paride4331
nildoe wrote:Hi Paride..
Hi nildoe,
thanks, I cannot replicate the issue, could you try using 442.19?
Are you using standard or DHC drivers?
Return to “Releases”
