OctaneRender™ 2020.1 XB3 [superseded by 2020.1 RC1]
jimho
still on the network renering for XB3
I found when using PMC engine, from the slave side it doesn't work right, see the image below:
it is jumping from 0 to 100percent all the time, and even worsely the slave may be killing by force again and again (so brutal the word used...)
Capture_network render6.JPG (18.87 KiB) Viewed 3760 times
though at the same time from the master side it is still OK
Capture_network render3.JPG (17.17 KiB) Viewed 3760 times
This situation only happens with PMC, when using path tracing kernel it is all right.
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
jimho
mojave wrote:
p3taotoy wrote:What am I missing... for a while after installing the later versions of the standalone....
You would get a folder with the slave install, run and uninsatall etc.
How do you run/install the 2020.1 XB3 slave?
The slave has its own installer now. Many users do install either standalone or slaves on any given machine anyway so this allows you to install just what you need.
for instance, to install only slave we still have to have the standalone installed, as mentioned previously the install batch file are only in the standalone but refer to another file in the slave folder,
so whatever it cannot work if you install the slave only,
I think this is something to be fixed for better user experience...
vijay
Lewis wrote:Sorry i posted this to wrong section (XB2) but can you DEVs fix this problem with universal material, in 2019.1.5 is correct and in 2020.XB3 renders black :(.
Thanks for the bug report. This will be fixed in the next release
vijay
funk wrote:BUG: Displacement autobump seems to break on scaled items
1. Load the orbx and select the rendertarget to start rendering
2. Select the DISP_MAT nodegraph and toggle displacement > autobump off/on to see the difference
Thanks for the bug report. This is now fixed and included in the next release.
p3taotoy
Running a Mac OSX Version of XB3
Running the slave XB3 version
The Mac sees the slave and says its updating but does not use the slaves even if I keep the rendering going a long time etc.
Any way to trouble shoot this?
p3taotoy
OK now it is using them... just took a long time
p3taotoy
Trying Mac OSX Slave XB3 now
Get this error when installing slave Daemon...
I checked the Launch Agents dir and there is no octane app in there.
Any ideas
Creating temporary launch script ...
Creating temporary launch agent ...
Copying bundle into /Applications and launch agent into /Library/LaunchAgents ...
32:177: execution error: Terminal got an error: cp: /Applications/.OctaneRender *Slave *.app: No such file or directory (1)
p3taotoy
any feedback o9n this one felklahs
PolderAnimation
Is there a way to get motion blur with scattered objects?
We have moving object all scattered with the scatter node. For each frame we wrote out a matrix but when we render it, we do not get motion blur.
Any work arounds?
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
BorisGoreta
Instances on geometry can't have motion blur, but if they are instanced on particles they can have motion blur. <- sorry, this is true for Lightwave users only
