Out of core... just a good marketing strategy
samsue
I added small assets and problem again, worst of all... you delete and keep having problems
samsue
It has no texture with more than 4096px, HDRi or Vertex Displacement. Its all Octane Proxy ...
What else can it be?
What else is it supposed to do? I can't do my job! I must tell my boss... "I've invested15k euros" to use OCtane and I can't make a small scene for Archiviz ...
Lewis
Can you try go back to Octane v 4.05 ?
I find that one much more stable and using less RAM for out of core option.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
jimho
samsue wrote:It has no texture with more than 4096px, HDRi or Vertex Displacement. Its all Octane Proxy ...
are you trying to render it within 3dsmax or do it in standalone?
you are doing an intereior or exterior scene?
And yes what version are you working on?
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
samsue
- 3dsmax, but i have exportet to Orbx and try to render on Standalone, i get the same problem.
- exterior
- 2019.1.5 - 8.17
Lewis
If you get same from ORBX in standalone then that is great option to send to DEVs so they can replicate those crashes and possibly FIX it.
Lewis
Skype - lewis3d
ICQ - 7128177
samsue
Yeah, I'll do that.
That was the last outdoor scene I use Octane, better use Corona or V-Ray, I knew I wouldn't have started another outdoor scene with Octane, it must work well with Quadros and Nvlink... but not GTX.
what pisses me off is I think Octane's the best engine I've ever used... but then the don't work with big scenes, and I started using it because of Out of Core.
If we were told, it wouldn't work with this or that, so I could get around the problem, and use somothing else like 4k maps etc...
jimho
samsue wrote: - 3dsmax, but i have exportet to Orbx and try to render on Standalone, i get the same problem.
- exterior
- 2019.1.5 - 8.17
if it is exterior view, I would suggest you to use as much as scatter instead of prxoy, proxy will not decrease poly numbers for octane it only makes 3dsmax display faster,
there is different way to use scatter, forest pack may the simplest for the exterior view.
I am curious to see you scene, if there is a way that I can download it, probably I may also take a look into it, see if there is a solution from our user side.
paride4331
paride4331
Hi Guy,
I think we have isolated this out-of-core issue doing a reproducible crash in SA.
So I'm sending the files to the developers and hoping to definitively resolve the issue.
Return to “Autodesk 3Ds Max”
