OctaneRender™ for Blender 2019.1.5 - 20.7 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
  • Upgraded to 2019.1.5
  • Enhanced the OpenVDB feature
    • Added missing options (velocity scale, velocity grid type, motion blur. . .)
    • Supported to customize absorption/scatter/emission/velocity grid id as SA
    • Fixed VDB volume renders as black box(SDF type) issue
  • Supported Octane Output ("Property - Output - Octane Output") as it is in SA
    • Supported to customize "Octane Export Mode", "Export File Format", and "EXR Compression Type"
    • The export results are put under the "Output Path"
  • Supported Mesh Type Optimization("Property - Object Property - Octane - Mesh Type") for final animation render
    • Avoid duplicate transform updates for objects that are not Movable
    • Avoid duplicate mesh data updates for objects that are not Reshapable
  • Added a new experimental "Auto" mesh type to detect and apply the optimization automatically
    • e.g. it can detect and apply "Reshapable" rules for the objects that are used as smokes
    • It's an experimental feature to help users get rid of the manual mesh type assignment. Please let us know if there are any cases that are not covered and handled incorrectly. We will keep on its improvements.
  • Optimized mesh updates in viewport preview
  • Removed redundant uploads for meshes(except meshes that are reshapable, modified, or in edit mode)
  • Supported Global mesh type
  • Supported object layer settings for Orbx proxy
  • Supported to use texture value for gradient texture
  • Supported to customize the OctaneDB texture cache folder("Preferences-OctaneRender-Octane Texture Cache Folder")
FIXES SINCE LAST RELEASE
  • Fixed some issues in Orbx Proxy
  • Fixed the volume render issue
  • Fixed render issue of the group nodes with multiple outputs
  • Fixed crash of texture reference
  • Some other fixes merged from the latest 21.3
You can read about new features of OctaneRender™ 2019.1.5 here:
viewtopic.php?f=24&t=73490
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 20.7 (2.81)
Octane Server - Enterprise Edition - 20.7
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 20.7 (2.81) Linux
Octane Server - Enterprise Edition - 20.7 Linux
OSX
DOWNLOAD
Blender Octane Edition - 20.7 (2.81) OSX
Octane Server - Enterprise Edition - 20.7 OSX
REGULAR LICENSES (FOR V4 USERS):
The download links, provided in this post, are intended for OctaneRender Enterprise License Holders (which requires OctaneRender All-Access). For users still using OctaneRender 4, it is possible to access this Test Release thanks to our specially-made "Regular" versions. The links for these "Regular" builds can also be found in the links below:
Windows
Blender Octane Edition - v20.7 (2.81)
Octane Server - Regular Edition - v20.7
Linux
OSX
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
Return to “Releases”
