OctaneRender™ 2020.1 XB3 [superseded by 2020.1 RC1]
enricocerica
mojave wrote:
enricocerica wrote: As explained later on, it finally has nothing to do with the scatter script.
The problem seems to be linked with my grass which is about 2.5 million instances. If I render the scene with the grass and I make a change, let's say changing a material or reloading a mesh of the scene while it is rendering with the grass, I cannot do anything else, I cannot move the camera anymore (no effect), I cannot render another render target, I can select it but without any effect, I cannot select a material over the image, ... the render seems to continue rendering the same render target and the only way to get back the control is to restart Octane. If I disconnect the grass node in my scene, I do not meet the problem, at least I couldn't reproduce it. The issue occurs with 2019 version as well as with 2020.
Is there any chance you can share a repro scene so we can look into this?
Will check if I could reproduce the problem with a simplified version of the scene because it is really huge ;)
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
Lewis
Hi guys.
Does XB3 support network rendering (enterprise license) ? i can't see my render slaves from standalone + win_slave installed on renderslave ?
Shows nothing on list when i enable render-slave and yet my batch file seems fine/in order when started.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
mojave
Lewis wrote:Hi guys.
It should work, I assume you made sure you are using the same version of Octane for master and slaves right? Does this happen to you using all Windows machines or a combination, with just this version or also others?
jimho
the slave works,
just the installing process is a bit weired, when installing the daemon you need to indicate the location for the bat file which is in the slave's folder
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
Lewis
I have BAT file working and if i open network render from Plugin side (LightWave with 2019.1.5 octane - right window) i see my slave (yes it reports that slave has wrong version but main thing is that it sees it), if i open network rendering panel from Standalone i see nothing in my slave list ? That way i'm sure my *.bat works and it's correct but for some reason Standalone see nothing on that list ?
Here is screengrabs
Lewis
Skype - lewis3d
ICQ - 7128177
jimho
Hi Lewis,
Plugin should also be 2020.1 XB3,
2019version master cannot use 2020.1 XB3
the slave is working, it just cannnot find the master which should be the same version
Lewis
Hi jimho,
please re-read what i typed :). I'm not trying to make plugin work. that is fine i can find and use plugin with 2019.1.5 work fine,also with 2020 bu standalone is not seeing 2020.xb3 slave. that is problem here :)
Lewis
Skype - lewis3d
ICQ - 7128177
jimho
Lewis wrote:Hi jimho,
if the master standalone is already right version, it should be working already, because through the plugin you can see the slave means the slave side is correct already,
just try restart the standalone at the master side, if it still not working , try reinstall the standalone at the master side...
Lewis
Tried all that already and no go. That is why i asked DEVs here does XB3 network render even work in standalone since it is not seeing anything on network. And i installed slave and standalone on renderslave anx rebooted both multiple times and still nothing.
Lewis
Skype - lewis3d
ICQ - 7128177
jimho
Lewis wrote:Tried all that already and no go. That is why i asked DEVs here does XB3 network render even work in standalone since it is not seeing anything on network. And i installed slave and standalone on renderslave anx rebooted both multiple times and still nothing.
have you try reversely, meanning runing your standalone from your slave PC and have a slave from your master pc?
another possibility is your network have issues, but your 2019 can see it, Strange!
