I have a problem rendering a pyro sim in Houdini 17.5.391 using Octane 2019.  No idea what causes it. I have Cached the sim to disk, not sure if that matters. I get the same issue when caching to RAM.
The render is displaying  correctly in the IPR but when writing to disk, I get an error message. Im gonna attach the message and hip file below.
Thanks for the help.
Edit: Your Captcha prevents me from uploading the hip file, I will try again later.
							Volume Rendering issue
- Mentaldevil
I uploaded it now, I tried rendering with full scene reload but the same issue keeps appearing.
I forgot to mention that I still get an image saved to disk, it just doesnt look the same compared to the IPR at all. If you want I can post a comparison.
Edit: Removing the backplate and render passes nodes seems to have fixed it, the error message still comes up but disk output now looks like the IPR.
- Pyro_Rapid_Explosion.v01.rar
 - (108.64 KiB) Downloaded 165 times
You can ignore the octane messages. They come from the scene cleaning functions and are not dangerous at all. I've removed them for the next Octane 2020 plugin build.
About your issue with the rendered files, the problem is that you have at least one pass enabled (the Noise one) but you are not using the $OCTANE_PASS tag in the filename, so all the passes, including this one, are exported to the same file overwriting the beauty main pass.
- Mentaldevil
Ah, thats good to know. Ive been wondering about why this happened. Thanks for the additional info.
Is it just me or are some of these smaller issues not documented anywhere? I have read the manual but dont remember stumbling across this.
I'm sure that there are features that are missing in the docs, but the $OCTANE_PASS variable is documented in the Octane ROP node topic
https://docs.otoy.com/HoudiniH/HoudiniP ... gsOutp.htm
