OctaneRender® for 3ds max® v2020.1-XB2 - 10.00 TEST
paride4331
HHbomb wrote:Hi, neonZ just try this scene. Thanks
Hi HHbomb,
I tested your scene using V2018, v2019 ans v2020, no issue or performance difference.
I attached a clip using V2019 like a sample.
tyflow.mp4
(32.55 MiB) Downloaded 3365 times
HHbomb
Thanks for testing... :cry: I have a problem with my v2020.
User avatar (Default)
merid888
octanrender test
i would like comment, the slot desapper when close the 3ds max 2020 and open again, look flat, not circule when opne normally the program
the image is 3016 x 2016 px, pathtracing mode, 100 subdivision, RTX actived, is incredibly fast, only 55 seconds, AMAZING !!!!!!!!!
Exterior Test
Exterior Test
nildoe
Hi..testing this.. can someone please explain why i have what seems to be duplicate material types?
also whats the difference between the "R" Universal, Diffuse and Glossy Material and the regular ones?
also..would it not make more sense for the hair material organization of parameters to have the MODE first and then the parameters? just a suggestion to tidy things up... :)
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
HHbomb
here is a crop of a render. Adaptative sampling is On and Denoising On.
Emissive material ( flames ) have some grain even when denoised (by adaptative sampling and denoising) because it have opacity map. :cry:
candemirdesign
Why otoy dont releases "2020 version and some newer version" for the reguler licance user?
I also noticed most newest version is "OctaneRender® for 3ds max® v2019.2-XB3 - 9.01 TEST"
Why this delay happening
I need caustic photon multipler settings like in vray.
You force us to have to use some other render engines for caustic renders.
Elvissuperstar007
organization of parameters to have the MODE +10000
coilbook
Hi Paride,
still a bug where itoo is not rendered.
scene crashes
sky is black even the sun is in the scene
I attached the scene through wetransfer; https://wetransfer.com/downloads/d534b8 ... 938/d81910
UPDATE:
If you reset material editor crash might disappear but it still doesn't fix itoo.
I just tried 4.04 6.17 and it renders itoo that is in the scene attached. They did something to itoo
neonZorglub
nildoe wrote:Hi..testing this.. can someone please explain why i have what seems to be duplicate material types?
Hi Nildoe,
Thanks for checking;
Sorry, the 'R' materials should be ignored, the normal ones should be faster in the material editor.
That's right, the Mode should be first, and ideally only the corresponding options should be editable / enabled..
The order of the options is matching what is done is Stand Alone, but I'll see if I can re-arrange a bit for this case..
paride4331
candemirdesign wrote:Why otoy dont releases "2020 version and some newer version" for the reguler licance user?
Hi candemirdesign,
Octane for 3dsMax v2019.1.5 - 8.15 is available here:
viewtopic.php?f=80&t=73563
Caustic tips:
Specular material > Dispersion Coefficient - Increasing this value increases the coloration amount and dispersion in the object's transmission and in caustics.
Path tracing Kernel > Caustic Blur - Reduces noise in caustic light patterns. High values result in soft caustic patterns.
PMC kernel > Rendering with PMC creates physically accurate lighting and caustic effects to produce the highest quality results, but it can also take the most time to render, depending on the scene.
Return to “Releases”
