OctaneRender™ 2020.1 XB2 [superseded by 2020.1 XB3]
Despot
aoktar wrote:
rohandalvi wrote:Hi,
I can’t find the cinema4d noises in standalone.
It requires to use from some special osl node. It will be available with C4D plugin.
That doesn't make sense.
According to the blurb, it says 'Added Cinema 4D noises to standalone. These will also be available from the Cinema 4D plugin.'
This, to me, impiies that C4D Noises are available in Standalone - as well as the C4D Plug-in.
I don't get from that description that they are mutually exclusive.
I fully expected to open standalone and find a new Noise node or see them bundled with the existing Noise node. Or perhaps living in the LiveDB with the other recent OSL textures, but they are not.
mojave
Despot wrote: According to the blurb, it says 'Added Cinema 4D noises to standalone. These will also be available from the Cinema 4D plugin.'
There is not direct UI access to Cinema4D noises in standalone at the moment as you expect. Cinema4D noises are in fact exposed via OSL built-in functions implemented in the Octane core for best performance.
They can currently be imported from ORBX imported from Cinema4D and also used via an OSL node. We have still to decide wether specific nodes will be available this feature as it is DLC specific.
We really appreciate your feedback. This is the reason why we release development builds, but please keep in mind the the forum rules when making any request.
Notiusweb
Okay...
The Hair shader....
No matter what settings throughout the whole material are applied or adjusted (Albedo mode, Melanin mode, IOR, roughness, etc), it can only produce a hard black, a grey, a white, or a gradient white to black.
No colors at all.
Opacity is great, just the colors need fixing.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Rikk The Gaijin
I've reported this issue on the Maya plugin section, but the Standalone have the same problem.
Bug with the Opacity mask over a material that uses random walk SSS.
The shadows projected on the head have the silhouette of the geometry, ignoring the opacity mask.
galleon27
Auto bump map in displacement doesn't work.
2020.XB1
2020.XB1
2020.XB2
2020.XB2
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Notiusweb wrote:Okay...
The Hair shader....
No colors at all.
Are you sure? I'm getting color.
Notiusweb
The Hair shader....
No colors at all.
A color? - Yes
But correct? - NO
Plugs: Enterprise
galleon27
Notiusweb wrote:
The Hair shader....
No colors at all.
A color? - Yes
But correct? - NO
The attachment HairColor_1.jpg is no longer available
The attachment HairColor_2.jpg is no longer available
The attachment HairColor_3.jpg is no longer available
Yea, for some reason it works just fine on curves but doesnt work on a primitive box.
melanin+pheomelanin
melanin+pheomelanin
albedo
albedo
linograndiotoy
The Hair shader....
No colors at all.
The Hair Material works on curves. That's what it is for.
Despot
Thanks for the response, sorry if my post was a little heated, I have amended it accordingly...
But I'm still not sure how C4D Noises are implemented in Standalone.
I think what I want to know is, will C4D noises be available in Standalone without using C4D ?
Thanks again
J
