I keep running into this error when I open a scene: // Error: line 744: Object 'TransmissionDefOctControlHsC' not found. and it leave the transmission channel completely greyed out, with any previously connect transmission nodes missing
I have a fairly simple translucent plastic cap, made of a spec material with a roughness texture, normal map, SSS medium and a color node mapped into transmission. If I recreate the material material with a new spec shader, the error is fixed but I have to do this every single time.
Any clue what this is about?
// Error: line 744: Object 'TransmissionDefOctControlHsC'...
Moderator: JimStar
C. RAM Capacity (i.e. 6 GB)
- itsallgoode9
- Contact:
- itsallgoode9
- Contact:
sorry, it's OctaneRender for Maya 2018.1.3-14.41 on Maya 2019.2
- itsallgoode9
- Contact:
I just updated the plugin and its still having the issue.
Thank you.
I will check it after the holidays, and release a fix if I will be able to reproduce it. Does it happen with any scene having transmission attribute of a specular material connected to a transmission node? Or just with some particular scene? It's just weird that nobody has ever reported it since the very old 14.41 release... I just can't check it right now, 'cause I'm not at work - there are long holidays already. And of course it got reported half an hour after the holidays started..;)
If this happens with some particular scene - it would help if you attach it...
- itsallgoode9
- Contact:
JimStar wrote:Thank you.
If I have a reproducible scene I'll replace it. It's happened across many many scenes. Have a great holiday!
- itsallgoode9
- Contact:
I think i've noticed that the error occurs when using an RGB node (maybe other nodes too?) connected to transmission. If I just use the color box by the slider to adjust the transmission color, I seem to not get that error.
I'm not sure if that's ACTUALLY the case or it just happens to be on this one material or something--I'm chasing a deadline right now so I don't have time to run specific tests but if you happen to be looking into this issue once you're back, you might quickly check to see if there's an issue there.
- itsallgoode9
- Contact:
I think i've noticed that the error occurs when using a node (texture or RGB) connected to transmission. If I just use the color box by the slider to adjust the transmission color, I seem to not get that error.
One thing I have noticed is that the octane material doesn't recognize that a node is connected even though there is obviously a line connecting a node
As I can see from your screenshot - it only affects the material's UI, the render-result should still recognize the transmission node correctly.
I can't reproduce it on my side - no errors in any of my tests.
But I've just guessed what could be happening in your scene and already did some changes that should likely fix it. The new 2020xb2-17.5 test release is almost ready, so you'll be able to try it soon. Just let me know if it fixes your issue...
