OctaneRender® for 3ds max® v2019.1.4 - 8.13
paride4331
coilbook wrote:Hi Paride,
can you tell them to look into phoenix ocean mesh. When we use ocean mesh liquid doesnt show up during rendering
Sometimes it will render but most of the time it wont
Here is the screen shot two bugs in one scene. Pure ocean mode works
Hi coilbook,
Developers are working on Ocean textures since I did the report.
Could you share a scene with holes, I cannot reproduce it.
coilbook
Hi coilbook,
Hi Paride,
I sent you the scene as PM. You might see terrain artifacts and ocean problems . The main problem is itoo/octane not updating grass for me. Please render from 460-465 when camera turns you'll see no grass, at least for me no grass. Octane just doesn't update itoo camera movement.
Thank you
paride4331
Hi coilbook,
it seems to occur first time the Octane viewport is open, using the 3dsMax camera, not with Octane camera, perspective and not in render.
I sent my report to developers.
paride4331
there is a bug where multi sub materials are clear in octane. it's a random bug
and when we switched polygon id to 1 (GREEN COLOR) in viewport the car is still blue. Octane has hard time updating materials in viewport
I attached the scene with multisub bug and where the car is blue even though it's green.
Hi coilbook,
I tested your file, something goes wrong, but as you can see in my clip, the issue does not seems to depend on multisub.
I sent my test to developers.
01.mp4
(2.7 MiB) Downloaded 1790 times
Return to “Releases”
