OctaneRender™ 2020.1 XB1 [superseded by 2020.1 XB2]
fantome
Thanks for your answer mojave.
Yes i am talking about texture based displacement on characters and props. Motion blur was not working properly with them in octane 4.0.
It looks to still have some problems in 2018. So i wanted to know if 2020 solve this issue ? because it is a huge limitation when using octane for animation.
Many assets today have some texture based displacement.
So is still not working in 2020 ?
thanks again for your feedback !
Cheers
E
Shamefestival
aoktar wrote:
Shamefestival wrote: Yeah that at the time was a very temporary fix. Ultimately solved nothing. Same issue. Yeah i'm not dependent on a wizard. I make my own magic. Just this issue hasn't changed which brings to mind why people don't mention Octane w/Animation so much. It's ok if it can't be fixed. That's why i'll try REDSHIFT instead.
Probably you have some C4D shaders(layer/noise) and crashed. Or some cuda crash at back and you didn't checked "CONSOLE" window. I've replied in your topic for help and you didn't answer it.
And it's not true that people don't use it for animations a lot, sorry!
I never did check the console and it could have been a noise shader. Was unaware that c4d noise shaders caused crashes. They worked no problem other times. In that post you were talking with another person, not me. I only injected myself because I thought I had a helpful solution.
I'm not saying people don't use it for animations alot. i'm saying for heavy productions like my project, it's probably rarely pushed that hard. General animation yes, but online there is not a lot of word of mouth about Octane being great for animation. Much more REDSHIFT talk. Obviously I wish that was not the case. Just tired of messing around all the time. Just want it to work. I know it's not easy and i'm grateful for your hard work. Just gotta try other things too and hopefully come back.
Notiusweb
wallace wrote:
Notiusweb wrote: 2 - some lighting scenarios and HDRI's will cause the hair to look like mirror-hair with the roughness too low. But, then if I raise the roughness the hair color then goes grey and is no longer a jet black.
Off the top of my head, I think the Hair Material could use a Specular node, that way even with the low roughness the spec could be scene adjusted to be less pronounced. See, I can easily adjust spec, and apply spec maps, with other materials shaders, just not with this special 'Hair' material. So it would help retain the jet black without turning mirror in some lighting scenarios.
For now I would like to avoid adding another texture in the hair shader at all cost, for performance reasons.
My preferred solution is to introduce varying IOR into the shader like the specular material, this would reduce the amount of specular reflection you are seeing at low roughness, and this is what I would do first.
Okay sounds awesome! am excited to try this out!
Oh, and if by some chance, you just so happen to be coding lines of code near the upsampling area of code, it would be really interesting, maybe, to see what a 1.5x upsampling mode could do... :P
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
divasoft
By the way, Ahmet, I repeatedly wrote to you about the problem of increasing render time frame by frame when using motion blur in c4d thread. To no avail.
divasoft
VVG wrote: You have the worst licensing system. It seems you yourself are confused and continue to confuse the regular users who are with you from the very beginning.
I asked for a support for a personal discount on the upgrade of the PERMANENT license from V4 to the PERMANENT 2020. I specifically waited for it. Not updated for 2018-2019.
Your support did not respond to any letters (there were several)
Why didn’t you meet your old customers and did not give a discount on the update on Black Friday. 499 euros is a large one-time amount for most!
WE HELPED YOU TO IMPROVE YOUR INTEGRATIONS, ACTIVELY SENT BAGGEPORTS starting from v1 - to V4 (the most terrible period of updating from V3 to V4).
And you do not need to indicate that the update from v3 to V4 was free, it would be better if it was paid and with a system license like REDSHIFT.
You just created a big headache for yourself and the rest with the current license system.
We are waiting for your discount on the update for V4 permanent licenses (499 euros)
+1
Agendum
Goldorak wrote:
Would you mind emailing me (Jules) directly so I can help sort this out for your one on one. [email protected] goes right to my inbox.
Is the discount supposed to be less than 499 euros for us perpetual V4 users?
linograndiotoy
fantome wrote:Thanks for your answer mojave.
Cheers
E
Texture Displacement doesn't support deformation motion blur. Vector Displacement does, and should be the best choice for deforming characters/meshes.
Texture Displacement only supports items and camera animation motion blur.
VVG
I wrote to Jules, but there is no answer yet.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
Jolbertoquini
Hi Guys,
me again hope everything is fine... I asked before and made a request aswell about Alembic cache sequences is that a way to add a support of alembic sequence? I have huge caches for particles and I would like to use only standalone to save time on load from the plug (Maya for me ) please let me know if would be possible.
Also I attached her a alembic cache of particles and I have the radius lock I don't know why doesn't work when I open on Houdini/Maya or others I get the radius lock inside Standalone.
I though in the first time is the usually bug which doesn't update the particles radius only when we click on other option on the alembic parameters.
Cheers,
JO
GranularParticleSystem.1050.rar
Particles lock radius
(23.53 MiB) Downloaded 231 times
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
ff7darkcloud
I decided to upgrade my v4 license and get a slave node license, but there is no way do download the slave client. How can I use 2020 on my slave computer?
( PC ) Win10 x64 | 2xRTX2080TI | ASUS Rampage VI Extreme | i9-7900x | 32GB | 1600W
( Laptop ) Win10 x64 | RTX2080Max-Q | Lenovo Legion Y740 | i7-9750H | 32GB - Octane Standalone Win 10/ Sketchup 2019
PORTFOLIO: https://renderspace.wixsite.com/portfolio
