Sigershaders for Octane Renderer | Max
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
samsue
- Lab 80 cm does not render the preview, as custom scene. The plugin opens the scene but does not render.
- I opened a 40 cm scene, it works normally.
From this scene I deleted the objects and put a plane, now no longer renders either.
Siger
Are you set as Custom scene in Scenes manager? (Right click - context menu - set as custom scene).
Siger
samsue wrote:- Lab 80 cm does not render the preview, as custom scene. The plugin opens the scene but does not render.
Thank you for the pointers! I found bug in Custom Scene preview render (Octane) implementation and broken 80cm Octane file. Now fixed. Very soon will released new minor version with some more fixes.
Antoncromas
Octane has an excellent material library online and offline. I dont think this is needed at all.
The reason people use Siger is because other engines dont really have a good library system and especially if you are using Max. . .
Return to “Resources and Sharing”
