Hello,
I have a 3d model of a sculpture coming from a 3d Scanner together with the material texture.
The model come in Obj format.
If I load the model in Lightwave everything goes well and the texture is perfectly applied.
If I turn in to an Octane setup and I apply a simple diffuse material with the texture applied everything becomes black.
The model seems a matte black
I tried all possible solutions:
If I load a different image on the model it works...
The texture comes in jpeg, I tried to check in Photoshop if there was something wrong, I converted the file in different formats and no way...it looks black (in Octane)
I opened the model in Modo and Blender and it works (native render and vray)
In lightwave works well with native render
In octane works well but when I turn the texture its full black..I tried to scale the model, to pump up gamma etc no way..
What could be the issue??
Thx
Strange texture problem
I have installed Octane for Modo demo and there the texture works fine...
vertex normals maybe ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
The model comes without Vertex Map...
- Rainbow-3D
Seems there is something in the texture file "no good" for octane in lw... and photoshop keeps it when saves it in other formats too.
Try to save the texture in a different program, like XnView. Maybe this doesn't resolve, but it is a fast try... (To me usually XnView resolves the rare problems of the image files, like some png (1 every 2000) saved from octane but corrupted only for AE: I load and save in that viewer, apparently nothing changed, but it "delete" the error for AE).
Win 7 x64 | Asus P8P67-M - i72600K | 16 GB RAM | 1 x nVidia RTX 2800
Win 11 | i7 13700K | 64 GB RAM | 1 x nVidia RTX 4090
If you want to send the model and the texture I could take a look at it. Perhaps the UV map name has spaces or not valid characters for the LightWave plugin, but it is hard to say what could be the problem without the object.
The texture file or the uvmap name? As I tried with the Uv map but no way...
Any, don't use special characters in texture file name, surface names or UV map names, Basically do not use special characters anywhere in model/textures and it should be good.spigolo wrote:The texture file or the uvmap name? As I tried with the Uv map but no way...
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
