I've been searching the forums for a while now trying to figure out a solve for this problem. I've got two passes: A beauty and a shadow. Both rendered with the same settings, each rendering a different set of layers marked with the Octane Object tag.
When I drop them in AE, I get a little line of alpha between my passes.
This doesn't happen with every render though. Some renders I've done in this sequence with the exact same models, HDRI, lighting setup, render settings, haven't had this problem. But a few have.
Any thoughts? Thanks so much!
