Octane 2019 For Unreal Engine - v0.25: Octane 2019.1.1
Moderator: ChrisHekman
ChrisHekman
Notiusweb wrote:So strange, when I next export back this now 2-cube scene from UE4 to Octane Standalone, the UE4 created cube is still warped, and texture inversion matches the issue in the plugin.
It's like there is something mirror going on with the UVs in UE4. I blame UE4 here.
Because, even If I completely disconnect the UE4 cube from its screwy pasted on plugin material, and then paste on a whole new simple Diffuse in the Octane Standalone, it's still messed up.
So, like the material the whole time is always fine in all circumstances.
Just somehow meshes from UE4 have some UV distortion thing going on that is preventing Octane standalone materials from being directly imported onto them.
There are a couple of things going on here.
Unreal uses V inverted UVs
Unreal uses Y inverted textures
This YFlip is copied over into the plugin. This was done because it keeps the UV calulations the same across shaders/materials. And keeping the textures yflipped makes texture conversion faster.
I am currently changing this as I was experiencing similar issues with a new feature.
The Octane Box primitive has a different UV layout than the unreal Cube.
The two boxes will not be the same, even when the y-flip issue has been fixed.
The Unreal cube has the entire texture on each of its faces, while the Octane box divides the texture by 1/6ths and places each part on each of the 6 faces.
The "Transform value" node rotation has a bug where it thinks it should have two values, making rotation not work.
Ill see if I can find the cause of the bug here. In the meantime you can change the transform node type from "Transform Value" to "2D Transformation".
Notiusweb
Cool Chris! Yeah, this will be awesome!
Thx for your informative descriptions, I was very confused by this. Thx for the help!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Uh Oh...
I just stumbled across something.
Plugin cannot respond to morph shapes can it....
I have a Live-Link to UE4 from iClone, where iClone generates morph shapes to UE4. The UE4 face moves around controlled from iClone, and the Plugin head likewise moves around, almost in Realtime.
But - the expressions and morph shapes, which do yes carry over to UE4, unfortunately do not then carry over into the plugin display.
So, the Plugin is not so much rendering the mesh 'shape' as much as it is converting it to an FBX-ish thing somehow, and thus can only 'mirror' hard bone-rig-type movements, but not morph blendshapes, right?... :cry:
Plugs: Enterprise
ChrisHekman
Im going to try to add morphtargets to the next build. Which should be released this week, or start of next week.
purpledancer
Hey there, I was wondering if anyone has found a fix for this issue. I use Brushify.io for my landscape material and World Creator 2 for the Height map, but Octane does not seem to be picking it up in the render viewport. I've attached an image with what I am talking about. Any help would be greatly appreciated. https://ibb.co/BtVgkjV
EDIT : I was thinking maybe the Octane Plugin for Unreal doesn't fuck with heightmaps, and maybe I would have to import the landscape as a mesh. :shock:
ChrisHekman
purpledancer wrote:Hey there, I was wondering if anyone has found a fix for this issue. I use Brushify.io for my landscape material and World Creator 2 for the Height map, but Octane does not seem to be picking it up in the render viewport. I've attached an image with what I am talking about. Any help would be greatly appreciated. https://ibb.co/BtVgkjV
Landscapes should work, however they were added in a newer version. You posted in the 0.25v release thread, so i assume you are using 0.25v?
You can upgrade to latest here: viewtopic.php?f=132&t=73883
purpledancer
Thanks Chris,
My landscape shows up now, but the landscape material does not seem to be supported-- I am thinking it may to have to do with the use of Layerinfo. I really appreciate you taking the time to answer these questions.
ChrisHekman
Thanks Chris,
The material should be supported to the same extent as other unreal materials (which means most unreal mat nodes are supported), and it should also support layerinfo.
Your terrain dosnt look that complicated, so im interested in what goes wrong.
Could you share me your setup? and how it looks?
purpledancer
ChrisHekman wrote:The material should be supported to the same extent as other unreal materials (which means most unreal mat nodes are supported), and it should also support layerinfo.
I would love to share in anyway - what would be the best method? Images, project files, etc.
-My scenes base is simply the Brushify - Environment Shaders Pack
-I've swapped out the starter terrain with an imported heightmap from World Creator 2 (PNG.)
-Landscape information: https://ibb.co/PMGvQ7G
-Current view: https://ibb.co/ssy7YQQ
Return to “Releases”
