How can I make those black circle lines gone?
Moderator: BK
truehuhuhu
In DAZStudio:
create a primitive object: plane (100m×100m)
give the plane an OC material: diffuse(just use a texture RGBimage)
set the OC environment: sun light
kernel=direct lighting
Then, render the scene: some black circle lines appear on the surface of the image, how can I make those black circle lines gone?
black circle lines
black circle lines
Hi. It is hard to tell from just a screenshot. It could be a scaling issue (so scaling the scene up or down might resolve it). Or try adjusting the Ray Epsilon.
truehuhuhu
Yes!You are right Paul, it is because of the ray epsilon!Thank you! :D
Return to “DAZ Studio”
