Material mixer
Hi, I am using material mixer and when I set the value to 1 I am not seeing the same material as if I plug it straight into output node. Also blending is not even. When the amount is 0.9 I am still seeing much of the blue color when blending from blue to red. Red being 1. Please help.
Hi, sorry I did not notice you replied. I recreated the problem on a simpler scene. I am sending one hip file and two images where if you pay a closet look. You will see that the edges of the box look different. With my scene, that problem gave a very different look. I hope it helps. Thank you. PS: just to say again, when I do the transition with procedural noise, everything works fine
- mat_mix_bug.rar
- (253.4 KiB) Downloaded 202 times
Yes, sorry for the late reply. I can reproduce this problem here, and I'm trying to build a scene like that in the Standalone to report it to the Octane core devs. Once reported I hope that they could be able to figure out what could be the problem to fix it.
Thanks for the repro scene!
