OctaneRender™ 2020.1.3 for Blender® 2.83 - new free tier!
sanjinLa
I think you can't use preview and final render at same time. It's not a bug.
Braca
I'm new to blender, moving from Maya, anyone knows how to solve this issue?
J.C
Braca wrote:I'm new to blender, moving from Maya, anyone knows how to solve this issue?
Hi, what is your issue? Can you describe what is going on?
System – Windows 11
Braca
HEy J.C I thought it is obvious from the image attached. The problem is that the Boolean output with the noise displaced sphere gives out a clean cut like there is no displace node there. But in Live view it is working perfectly.
J.C
Braca wrote:HEy J.C I thought it is obvious from the image attached. The problem is that the Boolean output with the noise displaced sphere gives out a clean cut like there is no displace node there. But in Live view it is working perfectly.
Are you using Modifiers? If so please check if modifier is marked for rendering – camera icon next to modifier's name.
System – Windows 11
Braca
Hey J.C thanks for reply, I actually figured it out, it is the modifier stack as you mention, needs to be enabled for rendering. ;-) Thanks!
linograndiotoy
Mille wrote:Today i almost became crazy to try to make the denoiser work.
Then i discovered that if you use the denoiser beauty pass as preview, it doesnt work in regular render.
So if i want render i need to change the preview to combined pass and switch the viewport view to solid or wireframe... then i can press f12.
Is there any workaround to have the denoised preview and the denoised render? And maybe to change viewport mode automatically when i press f12?
by the way i'm a beginner, but octane looks really good.
There's an issue that needs to be solved which actually isn't allowing the Denoiser Beauty pass to work properly when the Denoiser Beauty pass itself is used as Preview Pass.
It will be fixed soon.
celicboris
Hello,
Where I can find Vectron scripts? There isn't any that come with octane for blender in this free tier.
Thank you!
linograndiotoy
New Octane for Blender Free Tier build is now available (and is awesome):
https://render.otoy.com/shop/prime.php
This is a TEST version, so be prepared to have some issues. Do not use it for production.
NEW FEATURES SINCE LAST RELEASE
  • Upgrade to 2019.1.4
    Support Octane VDB animation(same as 18.x)
    Add converters for converting Cycles Principled BSDF to Octane Universal Material
    The converter can be found under "Material-Converters-Convert To Octane Materials"
    Now only "Cycles Principled BSDF to Octane Universal Material" is supported. More types can be added in the coming versions.
    Add OSL Delayed UV Projection
    Add Vertex Displacement Mixer
    Reorganize kernel as SA layout
    Support to disconnect visible environment
    Support to resolve the target node without outputs for octane DB material
FIXES SINCE LAST RELEASE
  • Removed deprecated environment settings structure
    Hide Eevee/cycles nodes in octane; hide octane nodes in other engines
    Fix subdivision mesh issue
    Fix color vertex data error
    Fix Z-Depth pass crash
    Fix the export issue for single frame scene
    Fix the ortho camera wrong positions issue
    Fix ortho camera render issue with portrait mode under final render
    Fix the auto-refresh issue for animated image
    Fix probabilistic render freezing on OSX
    Fix the int value scope issue
    Fix Eevee HDRI render issue
    Fix the ramp setting issue for gradient texture and volume ramp texture
    Fix some connection issues in the octane node graph
    Fix render the issue of AO texture in the kernel
    Rename "Toon Direction" to "Toon Directional"
    Rename "Matte" to "Shadow catcher" in Diffuse Material
    Change bump socket from float to shader type
    Remove Octane prefix
KNOWN ISSUES
  • Materials with dynamic layer configuration(e.g. Group Layers, Composite Materials) are not supported in LiveDB and LocalDB
    Global mesh type override is not included in the current release
Exaco
I think latest version is broken.
https://i.gyazo.com/ff01f7c3bd4a787e29b ... 2a5e00.mp4
Does nothing: https://i.gyazo.com/4d8a1b16071c18d1a91 ... c0c611.mp4
Edit: Nvm, forgot the server thing
