Try to hear my words, really hear it not just answer it.
I do this job for 20 years and today for the first time in 20 years i had to change my workflow in the middle of my production because octane V3 couldn't render high size any more.
So my advice, make otoy team strongly test updates before release, working with octane is just like playing lottery.
Anyway, i still crash with your settings.
I upload the file in attachment if you want to get an eye on it. (3dsmax 2018)
What driver do you use ?
OctaneRender® for 3ds max® v4.05 - 6.21
- paride4331
- paride4331
Hi thekwen,
yes, 3dsMax 2017, 2018 and 2019 too.
you could you try to install 436.48 Nvidia driver again.
To get an effective Nvidia drivers installed, please use [DDU Nvidia unistaller drivers](http://www.guru3d.com/files-details/dis ... nload.html) (safe mode unistall), the best way to get a clean installation.
Epilogue:
Reopening the same files that was working yesterday, 3dsmax crash ...
Testing ... testing ... to see that when i install 6.20 or 6.21 the hair and fur file works once and once only, after that it crashs ...
Downgrade to 6.14, everything seems to work more than once ...
Octane nightmare ...
- zerozerozero
Hi, I have the same problem. Have you been helped? Is there a solution? Or again roll back to the old version?Buraq wrote:Hi,
Another problem with 6.21. When I add the bitmap node, 6.21 is crashing.
- zerozerozero
paride4331, hi look please! When you add an image, the program crashes. This is in an empty scene.
