Hi there,
I am running into an issue where my image sequence is not playing through the animation sequence in octane.
I've made a new material and applied the first image in the sequence (keeping note of the frames in which case is 35),
then I went to the animation tab and set the start frame to 0 and the end frame to 35. I then apply this to a plane for testing.
I hit play and...nothing happens. It just stays at the first frame. I tried this with multiple different images as sequences and nothing seems to work.
I am using a .png sequence labelled as Glitch10000 to Glitch10035.
Anyone know why this isn't working?
Using octane 2019.1 R2 with C4D.
Image sequence not working to project animation
try
start=10000
end=10035
start=10000
end=10035
