Glass is not clear in AO mode
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
For some reason glass is not clear in AO mode when it is in the shadow. Similar bug was before in diffuse mode. using 2019.1
coilbook
coilbook wrote:For some reason glass is not clear in AO mode when it is in the shadow. Similar bug was before in diffuse mode. using 2019.1
Hi Paride,
any update on this one?
Also in old versions of octane I could have alpha shadows off and sunlight would still shine through the glass. Now it has to be on all the time.
paride4331
Hi coilbook,
I added your post to my report, I did it on May 16, 2017.
01 (1).jpg (18.81 KiB) Viewed 4121 times
coilbook
paride4331 wrote:Hi coilbook,
Hi Paride,
it was fixed in octane 4 but the problem is back in 2019 version
coilbook
HEre is the scene
when the object is in the shade glass is not clear in AO mode even with very low AO distance
Also in octane 4 I could turn off alpha shadows and still see objects well lit behind the glass with the sunlight. Now it always msut be on
Thank you
dark glass.zip
(708.47 KiB) Downloaded 320 times
paride4331
Hi coilbook,
I will update my test using your scene from V4 to V2019.
3dsmax.zip
(259.08 KiB) Downloaded 282 times
coilbook
Thanks. Above is a new scene I attached you can test.
paride4331
Hi coilbook,
this issue has been fixed in the next build.
Return to “Bug Reports”
