NVLink
I'm going to buy Enterprise edition this month. At the moment I'm using demo version and I can say that NV Link doesn't work at all. I have two RTX 2080ti. I had out of memory errors, too many polygons etc. Or Octane demo doesn't support NV Link ?
- alekpanfilov
- Contact:
C4D + Octane + Nvlink working
2018.1.3
R17
2x 2080ti
2018.1.3
R17
2x 2080ti
Ok NVlink is enabled but not functioning as it should. Crashes and out of memory like using one RTX card without doubled GPU RAM.
- alekpanfilov
- Contact:
NVidia Driver - 431.70 - stable rendering ( last few days 5000+ frames ) scenes around 5-8mln poly
NVIDIA Driver ( latest ) 436.15 - unstable / crashes randomly ~100-150frames
Creator ready? I've seen some reports about stability issues on latest driver.alekpanfilov wrote:NVidia Driver - 431.70 - stable rendering ( last few days 5000+ frames ) scenes around 5-8mln poly
Did you tried DDU before installing it ?alekpanfilov wrote:NVIDIA Driver ( latest ) 436.15 - unstable / crashes randomly ~100-150frames
How were you able to get it running in Octane?SSmolak wrote:Ok NVlink is enabled but not functioning as it should. Crashes and out of memory like using one RTX card without doubled GPU RAM.
I also made the NVLink Test with the tool you mentioned and its working. Still, no luck with Octane.
- nvlink.PNG (7.16 KiB) Viewed 5336 times
Is it true that only Quadro and Titan NVlink bridges doubles GPU memory ? I have Gigabyte Aorus bridge - it is the problem ?
Some technican from Nvidia said that Titan bridges are neccessary for double GPU RAM NVLink feature. So I bought one Titan RTX NVlink bridge and still get this :
I suppose that this Octane NVLink "feature" is only for advertising...
Peers from Octane Device Settings panel are always reseting to off state - maybe this is the problem ?
In Octane Standalone it works fine.
Bumping this for Aoktar to see
