Hello,
I need to have the best setting possible for maximum sharpness.
Someone can help me ?
I've 6 Titan X, no problem with render time !
Sharpness !
You can play with the Filter Size option in the kernel options.
By default the value is set to 1.25, but you can reduce it to 1...
Values under 1 may cause crisp glitches.
Be carreful to the Hot Pixels Visibility is set to 100% or 1.0, values under 1.0 can be use to remove some isolated grain in your image, but you'll loose the sharpness, same thing if you use the denoiser in the Imager Camera...
