Render-Layer Bug
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
NVN
Hi there!
On Octain Version 4.02.1-R3 there was a big bug on Multipass.
If u save your Multipass as PNG your color-range is false!
Ur object of Renderlayer has a color-range of 254 instead of 255!
NVN
if u save JPG (i wrote this bug since version 2!!) u got artifacts around ur white mask!
Looks like it will be saved as quality of 6 instead of 12....
Damn it...its no clean Multipass possible???
Here is a Picture-Capture with 500% zoom.
Could you please provide a scene?
NVN
Here u are:
If you render all your passes with "infopass-Renderlayer" seperatly they are perfect.
But if u want all together once they are false....so its a bug.
aoktar wrote:Could you please provide a scene?
MP.zip
(102.74 KiB) Downloaded 219 times
Only thing is right that max values are 254 if you use PNG, I'll check it! Other than this I cannot get dirty results with JPG, it's completely clean. What's you C4D version?
I've fixed the PNG254 problem. It was about unexpected results with C4D's pixel conversion functions.
NVN
Hi Aoktar,
there is still a problem with jpg-artifacts-output. Can u fix it also?
aoktar wrote:I've fixed the PNG254 problem. It was about unexpected results with C4D's pixel conversion functions.
Return to “Bug Reports”
