OctaneRender™ 2020.1.3 for Blender® 2.83 - new free tier!
Forums: OctaneRender™ 2020.1.3 for Blender® 2.83 - new free tier!
Re: OctaneRender™ 2019 for Blender® 2.8 - new free tier!
Postby davorin » Tue Jul 30, 2019 3:26 pm
davorin Tue Jul 30, 2019 3:26 pm
Well we can all say that it is far away from being usable at the moment...
I switched to E_Cycles already a while ago...not only because of the license lockups....but also due to the fact that most blender add-ons work for Cycles...
I'll give a it another try by end of this year before my subscriptions runs out (o;
Debian 10.2 on AMD 1950X, 64GB RAM, 2 * RTX2080Ti
Octane Blender Studio 2020.1-XB3-21.3
Blender 2.83 E_Cycles
davorin
Postby Greggers » Tue Jul 30, 2019 3:51 pm
Greggers Tue Jul 30, 2019 3:51 pm
This free tier etc is all confusing for me.
I purchased the standalone v4 and the modo plugin awhile ago. Then things became subscription for updates. I moved to the c4d plugin to test it out and ended up subscribing. However i stopped using cinema 4d and moved to blender and cancelled my c4d plugin subscription.
Please could you tell me my options to have octane integrated into blender 2.8 without subscription. I've had a play with it in blender and I like this release. Where do I go from here?
I have octane standalone v4 and no subscriptions and dont want to subscribe to the blender plugin for 2.8, just buy it.
Greggers
Postby ChrisH » Tue Jul 30, 2019 5:26 pm
ChrisH Tue Jul 30, 2019 5:26 pm
Three things to note (mostly for other users who might have similar experience to what I had):
1. If you open a file/import a material setup In Octane Blender 2.79 that uses reroutes, the materials won't work, Seems like reroutes isn't supported (yet) (you can't add reroutes in the Octane version of 2.8).
2. Some noodles will appear red (indicating that they "won't work"), but it should be fine. Octane Blender uses the input/output types differently/weirdly (Output from a texture node is "green"[/"shader"], while color inputs on shaders are "yellow"[/"color"] etc), and Blender shows them as "incompatible"..
3. The support for setting up Eevee/Cycles materials (etc) has been removed..
But overall it looks good.
(I'm trying to set up a model that I've been converting from Cycles in 2.79, just to play with it. I like it and I think it will be great when i's done! :D )
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
ChrisH
Postby AirzOVJ » Tue Jul 30, 2019 7:13 pm
AirzOVJ Tue Jul 30, 2019 7:13 pm
OctaneServe does not start and socket error is output and it does not start.
Blender also started if put in HDD, but did not start when put in SSD
AirzOVJ
Postby Lukasesch » Tue Jul 30, 2019 8:13 pm
Lukasesch Tue Jul 30, 2019 8:13 pm
Anyone else has the problem of Octane Daylight Environment making the scene contrast corrupt? With emmisive lights it looks fine.
Lukasesch
Postby cgslav » Tue Jul 30, 2019 9:36 pm
cgslav Tue Jul 30, 2019 9:36 pm
Do AI denoiser is working?
I've enabled it in Camera settings, turned on Beauty pass in Denoiser tab but I still can't see any result out of it.
cgslav
Postby louiscyan » Tue Jul 30, 2019 9:40 pm
louiscyan Tue Jul 30, 2019 9:40 pm
Gets stuck on "Rendering | Waiting for image..." in editor view
processor Intel i5-4590 @3.30GHz
RAM: 16gb
64 bit windows OS
louiscyan
Postby ChrisH » Tue Jul 30, 2019 11:56 pm
ChrisH Tue Jul 30, 2019 11:56 pm
Lukasesch wrote:Anyone else has the problem of Octane Daylight Environment making the scene contrast corrupt? With emmisive lights it looks fine.
Make sure you turn off "Filmic", it doesn't really work with Octane.
Set the Display Device to "None" in the Color Management.
ChrisH
Postby Alex_Pi » Wed Jul 31, 2019 12:15 am
Alex_Pi Wed Jul 31, 2019 12:15 am
Почему рендер не останавливается (1) на заданном значении (2), если я смотрю через камеру?
https://clip2net.com/clip/m581679/a70c6-untitled-1-291kb.jpg
Alex_Pi
Postby jfcalcena » Wed Jul 31, 2019 12:27 am
jfcalcena Wed Jul 31, 2019 12:27 am
Hello guys. Nothing works here. I already activated in Addon Octane Render and change it in the Renderer menu to Octane and nothing happens. I missing something? I followed exactly the steps informed in this thread and nothing works here. Follow prints. Thanks!
jfcalcena
PreviousNext
Users browsing this forum: No registered users and 42 guests
Sat Apr 20, 2024 3:36 am [ UTC ]
