OctaneRender™ 2019.1 RC3
haze
Dear all,
There are still some outstanding issues at this point, but we are making good progress for more fixes to arrive soon.
We still consider this an experimental build, until we leave the RC status. Please don't use this for production purposes.
Please also ensure that you have a NVIDIA driver version 419.x or newer.
Some known confirmed issues so far:
  • Upsampler picking is not working
  • Mix material (and composite material) anomaly when swapping inputs with amount = 0.5.
Changes since OctaneRender 2019.1 RC2:
  • Performance improvements.
  • Fixed glossy material not working with sheen layer.
  • Fixed metallic layer not conserving energy in universal material.
  • Fixed demo build color issues on 1080.
  • Fixed glossy material not fully reflective when IOR = 1 for microfacet models.
  • Fixed crash in preference panel component with desktop scale factor other than 100%.
  • Fixed vertex displacement crash when used with meshes that have vertex speeds.
  • Fixed black denoiser pass sometimes when subsample mode is enabled.
Downloads
Downloads for users with an Enterprise subscription license
OctaneRender Enterprise 2019.1 RC3 (Windows installer)
OctaneRender Enterprise 2019.1 RC3 (Windows zip)
OctaneRender Enterprise 2019.1 RC3 (Mac OS)
OctaneRender Enterprise 2019.1 RC3 (Linux)
Downloads for users with a Studio subscription license
OctaneRender Studio 2019.1 RC3 (Windows installer)
OctaneRender Studio 2019.1 RC3 (Windows zip)
OctaneRender Studio 2019.1 RC3 (Mac OS)
OctaneRender Studio 2019.1 RC3 (Linux)
Downloads for users with a regular V4 license
OctaneRender 2019.1 RC3 (Windows installer)
OctaneRender 2019.1 RC3 (Windows zip)
OctaneRender 2019.1 RC3 (Mac OS)
OctaneRender 2019.1 RC3 (Linux)
Happy rendering
Your OTOY NZ team
funk
Thanks team
sbstnc
Does authentication last longer than a single session yet?
PolderAnimation
When I render a 1024 x 1024 image with denoiser on, my denoised image looks fine but when I render it on 4k square, my non denoised images stills looks good, but the colors of my denoised image look inverted, I even got values of -0.75 instead of 0.9.
The denoised Indirect Reflection is also totaly wrong, In the left coner there is a small strip with the correct indirect reflection but the rest is a solid turquoise for some reason.
The normal indirect reflection pas is also not working properly.
edit: I have a file if that is requested. Let me know where to send it to.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
PolderAnimation
I have a setup that uses vertex displacment and a texture for the color input.
Why is it that when I change the UV transform scale of the color texture, that octane has to calculate for a minute before I see my result. When I disable the displacement, the changes are instant.
Elvissuperstar007
Started logging on 26.07.19 20:39:50
OctaneRender 2019.1 RC3 (6000004)
Up-sampling error: CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered
CUDA error 700 on device 0: an illegal memory access was encountered
-> failed to copy pitched memory from device
VVG
I already wrote earlier about this problem (I sent the scene aoktar)
viewtopic.php?p=366441#p366441
STDL 4.05
STDL 2019.1 RC3
Normal
scene
denoise bug.orbx
(273.32 KiB) Downloaded 352 times
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
PolderAnimation
When working on textures, like scaling and such, often the view-port does not restart the render. This makes look-def impossible.
vijay
VVG wrote:I already wrote earlier about this problem (I sent the scene aoktar)
STDL 4.05
STDL 2019.1 RC3
Normal
scene
denoise bug.orbx
Sorry for late reply and thanks for the scene. We will look into this.
Vijay
funk
CUDA crash when enabling rounded edges + texture displacement
1. Load orbx and click the render target to start rendering
2. Select the mat1 nodegraph
3. Set rounded edges mode = accurate
Cuda crash:
Started logging on 07.08.19 04:37:33
OctaneRender Enterprise 2019.1 RC3 (6000004)
  -> failed to wait for event
device 0: path tracing kernel failed
displacement_rounded_edge_crash.orbx
(83.09 KiB) Downloaded 346 times
