Curves in a rendered sequence
$HIP/render/$HIPNAME.$OS.$F4.exr. can you explain what I am doing wrong. In the octane tab I have the render as curve/ fur object turned on but this seems to work only in the ipr. why is that?
I'm not sure what could be the problem. The IPR and the final rendering to disk are the same, unless there was a problem with the motion blur while rendering sequences or something like that. Have you tried to render the scene in "Full Scene Reload" mode?
In any case, if you want to send me the scene, I could take a look at it here.
https://drive.google.com/open?id=1_p_7x ... 2kB105ryva here is the scene file. Not sure what "Full Scene Reload" mode is , but here have a look.
