Viewport freeze
Zinnur
When i start octane my viewport start freezing, regardless which scene, its can be one cube or something more complexity.
For example if in scene I have one cube and rotate viewport my fps turn down to 10-15 or less and start freezing.
Have tried to instal various octane version, cuda drivers, video cards doesn't help
Have tried switch render priority to PRIORITY_LOW, PRIORITY_MEDIUM, PRIORITY_HIGHT doesn't help to
Don't know what i should do that octane start working well?
iMac 17,1 High Sierra 10.13.6
NVIDIA Web Driver 387.10.10.10.40.105
CUDA Driver 418.163
GTX1080
Octane C4D plugin v2018.1.3
Cinema4D R19.068
you need to revert to CUDA 410.130 with High Sierra, by installing on top of the currently installed version:
https://www.nvidia.com/object/macosx-cu ... river.html
Please, also make sure to have disabled the Synchronize on geo update option, in Octane Settings / Others,. If enabled can cause instability issues under OsX.
ciao Beppe
Zinnur
bepeg4d wrote:Hi,
ciao Beppe
Ok, I disabled Synchronize on geo update and instal CUDA 410.130 and now fps ok(40-60) but freezes keeping
Activate all log output options in settings/other, then try again. Send c4doctanelog.txt if it freezes again.
Zinnur
aoktar wrote:Activate all log output options in settings/other, then try again. Send c4doctanelog.txt if it freezes again.
Yeah its still freezing, dont know if it help but when I start octane viewport in cinema4d become red for few seconds
c4doctanelog.txt
(16.5 KiB) Downloaded 214 times
Thanks for log. Could you record a video to show the process and problem? Please keep "Console" window is open and visible. So we can see where it happen.
Zinnur
Here is the video
test_record_001.mov
(13.77 MiB) Downloaded 3120 times
What I can say that's not directly a problem with plugin. But maybe a problem on nvidia drivers and c4d's opengl. Better to run with clean copy of C4D and refresh install of plugin.
Zinnur
Ok will try fix it, thank you for your time
