OctaneRender™ 2019.1 XB2
Notiusweb
Diffuse color on Metallic Material does not do anything, ie does not alter any color or restart render if changed.
I don't know if it is supposed to do anything?... (but would be cool if it did :D )
The reason I ask is because when added as a part of a layered material, the Diffuse Color is not part of the metallic layer, so was thinking maybe it is supposed to be inactive and maybe only operable in a certain specific situation?
Speaking of Metallic-a,
JUST CALL MY NAME 'CAUSE I'LL HERE YOU SCREAM....
OC-TANE!!
OC-TANE!!...
Oc-taaaaane....
Oc-taaaaaaaaaaayne
8-)
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
haze
funk wrote:I have a scene where AI light is making lights darker (even when there is 1 light)
Here is a stripped down scene with a single emitter mesh. When AI light is enabled, the light becomes darker.
Wallace has fixed this for next release.
J.C
Volume renderings got worse since the release of 2019.
It gets better when Old volume behaviour is disabled but there are still holes in volumes.
System – Windows 11
haze
J.C wrote:Volume renderings got worse since the release of 2019.
Can I please have an orbx with this volume?
funk
I'm doing some lighting tests with a scene and noticed the AI denoiser is giving me some strange results.
It's adding some extra facial features to the lego faces (kind of creepy!)
I have PMed the orbx link to haze
haze
funk wrote:I'm doing some lighting tests with a scene and noticed the AI denoiser is giving me some strange results.
Thanks funk, we're looking into it.
J.C
The attachment vdb issue.png is no longer available
Sure, here it is.
clouds_vdb3.orbx
(1.02 MiB) Downloaded 308 times
System – Windows 11
wallace
Notiusweb wrote:Diffuse color on Metallic Material does not do anything, ie does not alter any color or restart render if changed.
For more information about metallic material, please check: https://docs.otoy.com/StandaloneH_STA/S ... ight=metal
I'll explain it briefly here, basically the specular map controls the amount of contribution ratio of metallic specular reflection vs diffuse. By default, the specular map does not have a node, and this defaults to 1.0, meaning that there is full contribution of metallic reflection, and no diffuse contribution. This is why when you change the diffuse color, it doesn't seem to do anything, because there is no diffuse contribution anyway.
If you attach a texture node there, let's say grey scale, and reduce it to something less than 1.0, then you will start seeing the diffuse reflection there.
Notiusweb
Ohhhhhh....
Specular Map...
I mean, of course...Right, yes. Absolutely...Specular Map....I knew that
:oops:
THX!
Plugs: Enterprise
andrear
edit
I just realized that this build doesn't have any RTX support. Now, this makes the oddities even stranger.
may be it's normal behavior (I read the whole post here, but I don't remember any similar problems), but I found overall differences in the lighting scene and textures.
see the attached files, an interior scene I'm working on.
The first image is rendered with 4.04 while the other with 2019xb2.
No changes were made to the nodes except for a lower exposure value in the 2019 ones.
is this related to the way the rtx cores handle reflections and shadows?
I also see big differences on some textures, look at the ceramics or the inox steel taps.
another oddity is the vertical shift in the renders from the 2019 build, where you can clearly see the towels in the background that are cut and slid at the small opening between the two glass doors.
thank's in advance for your answer,
andrea
4.04 5000pass Pt. exp 1.5
2019 xb2 5000pass Pt. exp 1
2019 xb2 5000pass Pt. exp 1.5
MSi GE75 Raider 8SF - W10PRO - RTX 2070 8GB mobile
