How do I render a VDB sequence?
Forums: How do I render a VDB sequence?
Re: How do I render a VDB sequence?
Postby promity » Tue Apr 16, 2019 10:22 am
promity Tue Apr 16, 2019 10:22 am
Do you mean - rename this files or another option? Where should I paste this value - "Default_$F.vdb"?
Thanks.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Postby juanjgon » Tue Apr 16, 2019 5:53 pm
juanjgon Tue Apr 16, 2019 5:53 pm
promity wrote:Do you mean - rename this files or another option? Where should I paste this value - "Default_$F.vdb"?
Thanks.
In the filename. Put this expression in the OpenVDB file parameter and the plugin will replace the $F token by the current frame. BTW. there is an additional parameter to set a frame offset for this token.
juanjgon
Postby promity » Wed Apr 17, 2019 12:17 am
promity Wed Apr 17, 2019 12:17 am
Thank you.
Lightwave 3d
promity
Postby promity » Sun May 05, 2019 1:44 pm
promity Sun May 05, 2019 1:44 pm
I do not understand anything - I create a scene in which there is a null object and a sequence of VDB files. I make the settings, everything works well, Octane sees the sequence. Then I load the object with VDB stquence from this scene into the scene with my character etc - nothing happens. Octane does not display these volumetrics. But if I load the same object from the VDB sequence into an empty scene, everything works well. What's the secret?
Buuut! If I load only one frame of VDB from a sequence, everything works as it should:
Lightwave 3d
promity
Postby juanjgon » Mon May 06, 2019 8:46 pm
juanjgon Mon May 06, 2019 8:46 pm
Hmm, do you have other Null objects in the scene with this same name? The volume null should have a unique name in the scene to avoid problems with the "Instance LW clones" feature.
juanjgon
Postby promity » Tue May 07, 2019 3:32 am
promity Tue May 07, 2019 3:32 am
Thank you. I checked - I made a new null object, I gave it the original name, I loaded the sequence of the VDB files - no result. I loaded a separate file - everything is fine.
Lightwave 3d
promity
Postby juanjgon » Tue May 07, 2019 8:24 am
juanjgon Tue May 07, 2019 8:24 am
Can you share the scene with this problem to take a look at it here?
juanjgon
Postby promity » Tue May 07, 2019 8:28 am
promity Tue May 07, 2019 8:28 am
Yes, I will try.
I am currently working with the 4th version of Octane - can it be that this problem will not happen when upgrading to version 2018?
Lightwave 3d
promity
Postby juanjgon » Tue May 07, 2019 5:53 pm
juanjgon Tue May 07, 2019 5:53 pm
Hmm, sorry, but I can't find any problem in this scene. If I add a null including the Octane volumetrics, the OpenVDB sequence is loaded without problems. Are you sure that you don't have a problem with the OpenVDB files paths in your scene? Perhaps the relative path is not working or something like that. In the Octane log file you should get a message about what file is trying to load the plugin, and perhaps a warning about a not found file ... something like " - Volume object from the OpenVDB file xxxxxxxxxxxxxxxxxxxx"
juanjgon
Postby promity » Wed May 08, 2019 12:35 am
promity Wed May 08, 2019 12:35 am
Thanks. I found my problems with the VDB sequence. In the wrong path to the files.
Lightwave 3d
promity
PreviousNext
Return to Lightwave 3D
Users browsing this forum: No registered users and 22 guests
Thu Apr 25, 2024 9:03 pm [ UTC ]
