OctaneRender for Maya 4.04-13.40 [OBSOLETE]
Moderator: JimStar
Locked
JimStar
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 4
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 4.04
Please read the new features implemented from Octane Standalone 4 version our blog post.
Changes since version 13.39:
  • More improvements of the translation system to support animated OSL-dynamic attributes.
Windows DOWNLOAD
OctaneRender for Maya 4.04-13.40 Demo
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 4.04-13.40 [Windows]
OctaneRender for Maya Studio 4.04-13.40 [Linux]
OctaneRender for Maya Studio 4.04-13.40 [MacOS]
Jolbertoquini
Hi Jim,
Thanks for the update on the OSL side I think is really needed, appreciate to keeping improving that.
I spoke with Haze about a fix on the standalone to make work in our workflow things on the Lua script was changed from OC 4.0.3 he said is fix, could we have a update engine soon his release the new engine please?
In that way we can update the full workflow here to 4 and then for next step later on, to 2019's
Cheers,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Hi Jim,
Here a OSL script which a problem on the plug but not on the Standalone. the file path case for the link is showing on the standalone but not on the plug.
Please find attached here the file.
// Proof of concept ImageTexture node for OctaneRender.
// Code that 'disables filtering' is based on a method from Image2Screen shader by Franois GASTALDO.
// sRGB response calculation is based on the OCIO python source codes by Haarm-Pieter Duiker.
// Feel free to reuse and adapt.
// Cheers
// milanm.
shader mm_ImageTexture(
   string File = "1",
   int ToneResponse = 0
     string widget = "mapper",
     string options = "sRGB (IEC 61966-2-1):0|Gamma 2.2:2|Linear:3|Custom Gamma:4"
   int InversionOrder = 1
     string options = "Before Linearizing:0|After Linearizing (classic):1"
   float Gamma = 2.2 [[ float min=0.01, float max=10 ]],
   int Filtering = 1 [[string widget = "checkBox"]],
   int Invert = 0 [[string widget = "checkBox"]],
   point Projection = P,
   output color pixeltex = color ( 1.0 , 1.0 , 1.0 ),
   // get resolution of the texture as integer
   int res[2];
   gettextureinfo(File, "resolution", res);
   // Convert res to float so that we can
   // find the size of one half of pixel
   float resX = res[0];
   float resY = res[1];
   // Half pixel offset as float
   float oX = (1/resX)/2 ;
   float oY = (1/resY)/2 ;
   // Pixelate the UVs if filtering is disabled
   point pixelateduv = color ( 0.0 , 0.0 , 0.0 ) ;
   if (Filtering==0) {
   pixelateduv[0] = ( trunc( Projection[0] * (res[0]) ) ) / (res[0]) ;
   pixelateduv[1] = ( trunc( Projection[1] * (res[1]) ) ) / (res[1]) ;}
   else {pixelateduv[0] = Projection[0]; pixelateduv[1] = Projection[1];}
   // lookup the colors from texture file + add half pixel offset to UVs if filtering is disabled
   color col;
   if (Filtering==0) {
   col = texture( File, pixelateduv[0]+oX, pixelateduv[1]+oY );
   else {
   col = texture( File, pixelateduv[0], pixelateduv[1] );
   if (Invert==1&&InversionOrder==0) {col = 1-col;}
   color lin;
   // sRGB (IEC 61966-2-1)
   if (ToneResponse==0)
      float a = 1.055;
      float b = 0.04045;
      float d = 12.92;
      float g = 2.4;
      if (col[0] < b) {lin[0] = col[0] / d;}
      else {lin[0] = pow(((col[0] + (a - 1)) / a), g);}
      if (col[1] < b) {lin[1] = col[1] / d;}
      else {lin[1] = pow(((col[1] + (a - 1)) / a), g);}
      if (col[2] < b) {lin[2] = col[2] / d;}
      else {lin[2] = pow(((col[2] + (a - 1)) / a), g);}
   // Gamma 2.2
   else if (ToneResponse==2)   {lin = pow(col, 2.2);}
   // Linear
   else if (ToneResponse==3)   {lin = col;}
   // Custom gamma
   else   {lin = pow(col, Gamma);}
   if (Invert==1&&InversionOrder==1) {lin = 1-lin;}
   pixeltex = lin;
Cheers,
JO
Maya Missing part
Maya Missing part
Standalone
Standalone
JimStar
This is not a bug, but a user-error.
Please be sure you don't use in your script the names of already existing non-dynamic plugs of the OSL-node.
In your case the "File" input variable is conflicting with the existing permanent "File" attribute of the OSL-Texture node, so it gets not created as a dynamic attribute. Just change the name of this variable in your script to something else (e.g. to "FileInput"), and it will appear in AE as a dynamic attribute of a "string" type.
In next version I'll improve the UI for the string attributes, so that they will be presented as a file-path in AE (with a pick-file button)...
Jolbertoquini
JimStar wrote:This is not a bug, but a user-error.
Hi Jim,
Okay I see, well would be great to work as Standalone so we can use the same OSL scripts without modified then for the plug only, I have multiple script on the standalone with the same file name and is working without errors? but not on standalone those script.
Cheers,
JO
Locked
Return to “Releases”
