Octane Render for SketchUp 4.00.0.20 [OBSOLETE]
manos
Hello... When exporting to the standalone version of octane the material picker doesn't work.... Please help....
CPU: INTEL i7 3.40 GHz/RAM: 8 GB/GPU: 2XGTX690/OS: WIN 7 64 BIT/SKETCHUP 2014/OCTANE for SU
_qmvc3WkfIhgYS
When can we see a fix to the problems with this release?
johlanga
Instant crash if I use any other kernel than "Direct lighting".....
And the UI setup are trashed after I reopen the crashed file.....
NB: this was OK before u "fixed" the layout >>> "* Handling of the Octane workspace layout has been changed slightly. Loading a new scene that doesn't have a layout saved with it will now revert to the default layout instead of keeping whatever the layout happens to be at the time, and there is a new menu option to reset the layout to the default."
Win7 Sp2____2xGTX1060 [email protected]____Su17.2.2555 and Su18.0.16975____SketchUp Plugin 4.00.0.17____4.00.RC7 Standalone
_qmvc3WkfIhgYS
What version is recommended that I revert back to for production use? 3.4.4.5?
Seekerfinder
patrickbarnekow wrote:What version is recommended that I revert back to for production use? 3.4.4.5?
No version. This plugin has sadly never been stable enough for production use.
ArchMP
ArchMP
This is the sad truth
jrlc7510
Sketchup 2019 plugin?
At the moment the plugin for Sketchup 2019 is available only for OctaneRender 2018.1.12:
viewtopic.php?f=31&t=71331
A new version for v4 will be published next week.
If you own a v3 license, and want to use v4, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps: ciao Beppe
ArchMP
Hello to all.
Despite the various failures of the Sketchup plugin, I am stubborn and keep trying to work on it, because unfortunately I think Octane Render is still the best.
Why if I start the render from Sketchup (OctaneRender_for_SketchUp_2018_4_00_0_20_win plugin), Octane 4.00 opens but does not render anything?
I must necessarily export scene in OCS and open it with Standalone.
It may depend on the fact that the document folder has been moved to the new NVME HDD with drive letter D:? In case there is a way to restore the paths?
P.S.
Is the last perpetual version usable 4?
Log file created at: 2020/02/03 17:08:27
Running on machine: DELL7530
Log line format: [IWEF]mmdd hh:mm:ss.uuuuuu threadid file:line] msg
I0203 17:08:27.400892 12436 app_manager.cpp:56] Init AppManager...
I0203 17:08:27.400892 12436 app_manager.cpp:62] Loading Octane dependencies from: 'C:\Users\Dell7530\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins\octane_render\ext'
I0203 17:08:28.391242 12436 app_manager.cpp:72] Octane dependencies sucessfully loaded.
I0203 17:08:28.391242 12436 app_manager.cpp:171] Checking for activation
I0203 17:08:28.391242 12436 app_manager.cpp:182] Trying to activate...
I0203 17:08:36.086108 12436 app_manager.cpp:185] Result: activated
I0203 17:08:36.086108 12436 app_ruby_extension.cpp:19] Ruby extension init...
I0203 17:08:36.086108 12436 app_ruby_extension.cpp:29] Ruby extension init complete
I0203 17:08:36.086108 12436 oct_manager.cpp:54] Creating OctaneManager...
I0203 17:08:36.096051 12436 oct_manager.cpp:64] OctaneManager Created
I0203 17:08:36.096051 12436 su_manager.cpp:47] Creating SketchupManager...
I0203 17:08:36.096051 12436 su_manager.cpp:81] SketchupManager Created
I0203 17:08:36.096051 12436 mat_manager.cpp:50] Creating MaterialManager...
I0203 17:08:36.096051 12436 ocs_loader.cpp:24] Creating OcsMaterialLoader...
I0203 17:08:36.096051 12436 ocs_loader.cpp:30] OcsMaterialLoader Created
I0203 17:08:36.096051 12436 scene_editor.cpp:31] Creating SceneEditor...
I0203 17:08:36.096051 12436 scene_editor.cpp:36] SceneEditor Created
I0203 17:08:36.096051 12436 mat_manager.cpp:62] MaterialManager Created
I0203 17:08:36.096051 12436 app_manager.cpp:85] ApplicationManager Init Complete
Return to “SketchUp”
