Login/logout option in 17.5.173 2018.1.
Log Off works as expected.
Log In do the login but close Houdini without any warning.
Log In to account via Houdini Plugin Crash
C. RAM Capacity (i.e. 6 GB)
- blobbybarack
- Contact:
Are you talking about the license management option available in the plugin options panel? You don't need to login from it at all. The plugin should ask for the license login/password information automatically once you try to render something if the license is not active in your system. Don't you get the login window when you try to render something?
- blobbybarack
- Contact:
Yep talking about the license management option. All true. But using it to relog in crash Houdini. No problem if you click ipr to relog back.
- blobbybarack
- Contact:
In fact most of the time both ways leads to a crash. But the login works anyway.
