Octane Volume BOX
Sub forum for feature requests etc
Moderator: JimStar
Jolbertoquini
Hi Jim,
Please would be great to have a similar tool as this one on the C4D plug inside maya http://www.aoktar.com/octane/OCTANE%20H ... erial.html would be great to have similar setup with volume and a support of the 3D noises in Maya.
I tried with the actual maya fluid but doesn't work at All cause doesn't support the texture and opacity option, and static grid.
PS...I know I can export VDB and etc... but we need a proper support of Maya features....
Cheers,
JO
Preview
Preview
Atmosphere.zip
Maya Scene
(19.93 KiB) Downloaded 344 times
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Hello Jim or Dev team...
Any reply on this????
BK
Jolbertoquini wrote:Hello Jim or Dev team...
Hello Jo,
Thank you for the follow-up.
Jim is currently looking into it to see if we could add support to Maya Fluid using its' shader/texture.
Could you please share a sample with the Static grid issue?
We will keep up to date if we find anything!!
Cheers
Kind Regards
bk3d
calus
BK wrote: Jim is currently looking into it to see if we could add support to Maya Fluid using its' shader/texture.
Hi Bikram,
Current fluid support in the Maya plugin is very very limited, 95% of the Maya fluid features are just ignored...
Please show this link to JimStar, this could help to implement a proper Maya Fluids support :
https://around-the-corner.typepad.com/a ... hader.html
Pascal ANDRE
Jolbertoquini
BK wrote:Could you please share a sample with the Static grid issue?
Hi Bikram,
first message if you check there is the scenes...
Screenshot
Screenshot
Return to “User Requests”
