HDR Files fail to load.
everyoneishappy
I can load some, but from this particular exporter they fail to import. Any hints?
https://www.dropbox.com/s/5j8n6eje05efi ... t.exr?dl=0
https://www.dropbox.com/s/ueklrzajv83uc ... n.exr?dl=0
What kind of hint you need? Did you try to load your files on different softwares?
everyoneishappy
Hey, thanks for quick reply.
They also would not open in photoshop. It's a custom exporter and I can talk to the dev about it, but might be handy to know some specs to tell them.
Can I safely assume octane will read all of the HDR depth and compression modes that it writes?
I don't know which forms of exr can be loaded by octane, but I tried on several software without luck. Only C4D viewer can open it.
everyoneishappy
Would be nice if there was a specification to pass on. But otherwise ok, I will export and test some as samples at least.
