OctaneRender® for 3ds max® v4.02.1 - 6.15
paride4331
perro_abombao wrote:Hi ...I have problems with infinite plane support...an old version file crahes 3ds max, when I try to use it...and native tool in this version doesn´t work...(modifier octane geometry properties)
Hi perro_abombao,
set the plane to movable proxy.
solomon
Will 3DS Max 2020 get support soon?
Solomon W. Jagwe
3D Artist/Animator/Modeler | Independent Film Director
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
paride4331
solomon wrote:Will 3DS Max 2020 get support soon?
Hi Solomon
viewtopic.php?f=27&t=71217#p360640
solomon
Hi Guys,
I just noticed that some aspects of the Octane objects are missing in this version, which were present in 6.14 ~ where can I find these settings?
Solomon W. Jagwe
coilbook
Hi Paride,
any news about slow material editor? Even typing is slow after using octane viewport and messing with mesh and materials. I 've attached the video\
slow mat.MOV
(3.08 MiB) Downloaded 2449 times
paride4331
solomon wrote:Hi Guys,
Hi Solomon,
developers are moving some features to 3dsmax modifier:
viewtopic.php?f=27&t=70773
neonZorglub
Hi perro_abombao,
You could try first to disable the infinite plane for your object after loading the scene:
In the standard 3dsmax object properties, User defined tab, there should be a line
octane_special_obj_type = 1
that you can remove, or set '= 0'
You could then try to create a more simple object (eg a plane, with a simple octane material), that you can set a infinite plane.
Also, when loading from an old version (without the modifier), you can keep the 'object special type' : Infinite plane in the octane Object properties, as previously, by turning off
'Move Geometry settings to Octane Properties Modifier' in the 'Prev Versions' tab of global settings.
I hope that helps.
Return to “Releases”
