Cinema 4D version 4.02.1-R3 (Obsolete stable)
momade
So I am a bit behind, and want to jump into Octane4, as the last production is over. Now I see Octane 2018 in the forum.... What is the difference?
Kalua
momade wrote:So I am a bit behind, and want to jump into Octane4, as the last production is over. Now I see Octane 2018 in the forum.... What is the difference?
Take a look at this post.
It shows the new features over V4:
viewtopic.php?f=24&t=70809
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
momade
Thank you Kalua.
I bought Octane 2 several years ago and did not have to buy 3 or now 4 if I understood right.
In the thread you mention it saiys I need a "Studio or Enterprise subscription license". Would that be what I have since I purchuased, or is that a payment model that I would need to start when going for Octane 2018?
Best.
Moritz
desire
Hi!
Have just checked the latest stable 4.02.1-R3 - the problem with noise in a BlackShadow Pass (through RenderLayer feature) hasn't gone... Since months.... :(
Can't beleive that just I single have this issue. The same on two different PC machines.
Dear friends how do you make renders with Render Layer?
Update: also with 4.02.1-R3 have repeatedly crashes while select and drag targeted Octane Light Object with active LiveViewer and splited viewport (persp+right+top+front)
niestudio
desire wrote:Hi!
Can you post a scene where you have this issue? I render with black shadow always, and have never seen this.
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
desire
niestudio wrote: Can you post a scene where you have this issue? I render with black shadow always, and have never seen this.
Okay, I've attached a file to a message.
By the way, in my case, this issue is not related to one scene - every time I render with RenderLayer and BlackShadows active, on both PC machines, I have noised and fireflied shadow pass in a result..... (
boxes-for-.zip
scene
(221.77 KiB) Downloaded 232 times
niestudio
Interesting. I notice your samples are extremely low (75). I guess I'm not seeing similar results as I'm typically rendering much larger files with 5000+ samples.
I tested your file in Standalone, and the results are similar, so you should probably post there. Don't think there would be an update on the plugin side that would change this for you.
In the meantime, in photoshop, you should be able to clean this up with the dust and scratches filter. Somewhere around 1px and 5 threshold should do it.
note: You won't be able to apply it on the transparent layer, but if you merge it with a white solid layer, you can then apply it.
Hi desire,
sorry, the issue with black shadow is known, and will be fixed with the upcoming 4.03 SDK.
ciao Beppe
eyeonestudio
Hi Ahmet.
4.02.1 R3 does not have c4dOctane-R15.cdl64. (I use R5 now)
If the 4.03 SDK is released, I would like R15 to be included as well. :)
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
eyeonestudio wrote:Hi Ahmet.
I know but I cannot build it without problems. I'll try to make it happen but no promise.
Return to “Releases”
