NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Locked
helloidonthaveanyideaformyusername
the blender demo also have a cuda error 999 is this normal ? i can't try octane right now
Which Nvidia driver version have you installed?
Probably you need to perform a clean installation of 417.71 version.
ciao Beppe
JayYoon
Any mac users?
I've installed 4.02 r3 with 410.130 and can't render anything with octane.
So I've reinstalled octane 3.08.4 but still can't render.
Is there 417 driver for Mac ?
CUDA 410.130 are working correctly under 10.13.6.
Probably the Nvidia GPU drivers or something else.
Please, go to Apple menu, About this Mac, then press the System Report button, then go to menu File/Save, and share the resulting .spx file, thanks.
ciao Beppe
Ashiyawolf
I was using Octane fine and then suddenly it started giving me render failure messages with Cuda Error 999. It worked in both Cinema 4D r19 and r20. Now it doesn't work in either.
I had Octane 4.02.1 working with C4D plugin 4.02.1-R3.
I went back to Octane 3.08.5 with C4D plugin 3.08.4 and I'm still getting the error.
I'm using Windows 10 Pro with Nvidia driver 419.17. I have two EVGA 1080 TI SC2 cards.
TonyBoy
You may need to role back to Nvidea 417.XX.
jbecaud
Hello,
I use Octane 4.02.1 on Cinema 4D R18 on Mac OS X 10.13.6 and I have a problem because the Live Viewer window does not show anything.
I'm using a GeForce 1080 GTX 1080 8192 MB card
I installed the latest version of the driver Cuda Nvidia V. 418.105 and I wonder if the problem comes from that.
If so, what is the best way to install the previous version please?
Here is the content of the Octane log :
Started logging on 30.03.19 21:44:21
OctaneRender Studio 4.02.1 (4020100)
CUDA error 715 on device 0: an illegal instruction was encountered
-> kernel execution failed(kernel0)
-> failed to deallocate device memory
-> could not get memory info
Thank you,
Ashiyawolf
Thanks TonyBoy. I went ahead and uninstalled the NVIDIA driver, went into safe mode and used Guru's uninstall for NVIDIA. Made sure I had no internet connection this whole time. Went back into normal mode and installed 417.71. Everything works again now.
Since I had downgraded to Octane 3.08.5 with C4D 3.08.4, I went ahead and left it there instead of trying 4 again.
It's working with both r19 and r20 of C4D. Frustrating that it worked fine with both using Octane v4 for about a month, then just blew up on me.
TonyBoy
Ashiyawolf, I use V4.01.1-R2, the version that works with your installed driver.
jbecaud wrote:Hello,
Thank you,
With Mac, you need to go back to 410.130:
https://www.nvidia.com/object/macosx-cu ... river.html
and install directly on top of the current installed version.
ciao Beppe
Locked
