RTX OctaneBench 2019 Preview
coilbook
Will RT cores work with AO kernel?
poojagite_2391
Currently they are getting about 3X rendering performance on RTX cards with the RT cores enabled. Right now it’s only Windows. :frowning: The Linux and OSX versions are waiting on Nvidia drivers to be updated.
I am a hardware and network engineer.
roinigo
Hi!
Here's my benchmark (RTX 2080 Ti with/without GTX 980) with 419.35 Nvidia drivers
ASUS PRIME X470-PRO
AMD Ryzen 7 2700X 8 cores
Noctua NH-U12S SE-AM4
G.SKILL FLARE X SERIES 64 GO (4X 16 GO) DDR4 2933 MHZ CL16
RTX 2080 Ti + GTX 980
Seasonic PRIME 1000 W Gold
Fractal Design Define R6
creyes
Revisiting this, I still can't get RTX to work with my Titan X. I swapped the cards so my 2080 Ti is in the first PCIe slot, and I'm still not getting the RTX check.
If I remove the Titan X and just run the 2080Ti solo then it works fine.
roinigo
creyes wrote:Revisiting this, I still can't get RTX to work with my Titan X. I swapped the cards so my 2080 Ti is in the first PCIe slot, and I'm still not getting the RTX check.
Hi! Did you get the last Nvidia drivers ?
ASUS PRIME X470-PRO
creyes
roinigo wrote: Hi! Did you get the last Nvidia drivers ?
I tried installing through geforce experience and by downloading drivers directly from Nvidia's website. Didn't notice any difference.
efekturk
Rtx 2070 laptop octane render performance. cooling performance good max 70c
Gianni
just downloaded the RTX OctaneBench 2019 Preview (zip and installer) and I have no RTX enabled with the configuration below:
Dell XPS 9560
Razer Core X + RTX 2080 Ti
Windows 10
NVidia driver 419.35
I also tried to disable the GTX 1050 in the Device Manager but nothing change.
mojave
Hi Gianni,
We have noticed other users using also your same EGPU solution that have come across the same issue. It seems that the driver does not report the GPU as an RTX device.
We will investigate but it may require NVidia's support so will post it here when there's any feedback.
Thank you.
concepto
Great with 9 2080ti :)
