Houdini Udim Setup
Forums: Houdini Udim Setup
Houdini Integrated Plugin
Houdini Udim Setup
Postby timcgi » Wed Mar 20, 2019 8:21 am
timcgi Wed Mar 20, 2019 8:21 am
I have the setup already tried at UDIMS one time eight and two times 4.
Also I have the Filepath correct with the <udim> in the end but it doesnt work.
https://imgur.com/ahHugh5
timcgi
Re: Houdini Udim Setup
Postby juanjgon » Wed Mar 20, 2019 9:26 am
juanjgon Wed Mar 20, 2019 9:26 am
Can you please try to set the grid size to 5x5 for example and try again? If this doesn't work, can you please send me the scene to take a look at it here?
juanjgon
Postby timcgi » Wed Mar 20, 2019 12:59 pm
timcgi Wed Mar 20, 2019 12:59 pm
Tried it with 5x5 did not work :(
I have packed for you the whole setup in a rar and attached the associated files such as mesh and textures. if you could look over it would be a dream!
Download: https://www.file-upload.net/download-13 ... 1.rar.html
Tim
timcgi
Postby juanjgon » Wed Mar 20, 2019 1:32 pm
juanjgon Wed Mar 20, 2019 1:32 pm
Thanks for the scene, I'm investigating your issue. Perhaps there is a bug in the code that processes the UDIM filenames, but meanwhile ... can you please check what happens if you set the grid size to 10x10?
juanjgon
Postby timcgi » Wed Mar 20, 2019 4:23 pm
timcgi Wed Mar 20, 2019 4:23 pm
The 10 x 10 Setup works for Color but not for Displacement.
Tim
timcgi
Postby juanjgon » Thu Mar 21, 2019 10:53 pm
juanjgon Thu Mar 21, 2019 10:53 pm
Sorry, I'm still trying to figure what could be the problem, and what you say about the displacement is even weirder. I hope to know more soon ...
Thanks for your patience,
juanjgon
Postby timcgi » Fri Mar 22, 2019 9:41 am
timcgi Fri Mar 22, 2019 9:41 am
No problem, take your time.
Many thanks!
Tim
timcgi
Postby juanjgon » Wed Apr 03, 2019 9:16 pm
juanjgon Wed Apr 03, 2019 9:16 pm
Sorry for the late reply. I've found and fixed the problem with the UDIM files in the plugin. It was a tricky issue related to the filenames order in the udim texture node. I'll include this fix in the upcoming new Octane 4.03 and 2018.1 builds.
juanjgon
Postby timcgi » Wed Apr 03, 2019 10:37 pm
timcgi Wed Apr 03, 2019 10:37 pm
Thanks so much, this will be a great update for those who use udim in Octane. Will the naming with <udim> the same?
timcgi
Postby juanjgon » Wed Apr 03, 2019 10:39 pm
juanjgon Wed Apr 03, 2019 10:39 pm
Yes, it is the same workflow, using the <udim> token in the filename.
juanjgon
Return to Houdini
Sun Jun 07, 2020 10:40 am [ UTC ]
