Cinema 4D version 2018.1-R3(obsoletestable) - 29.03.2019
VVG wrote:and why Spectron appeared only in the final release of v5 c4d? Why we did not test it in RC assemblies? In the standalone version, it has long been.
I haven't had time to add it due to working on different things. Bug fixes, improvements, etc..
and windows demo package has dlls for normal version, so crashed by this reason I believe. Fixed the package.
dococtane wrote:Thanks for the new build Aoktar, it looks pretty good so far.
I have a strange bug though. I opened an older scene from 2017 and by rendering it, Cinema crashes without an error message. With Octane V4.02.1 the scene renders without any problems. I did some testing and noticed that a few Materials cause this Issue. Actually the textures seems to be the problem. I was able to fix the issue by renaming the same textures and reconnecting them in the material. They are all located within the regular tex folder. Renaming and reloading all the textures would be pretty unpractical, any idea what causes this?
Tobi
Hi again,
I tried your scene in R18/R19. I cannot see any problems. How to reproduce the crash?
VVG
demo now work.
1. but Spectron's original problem is not solved.
2. and to much noise in env
Who needs a useless Vectron when people more often work with light?
3. old problem to (viewport transparent) often appears
until you enter the material and forcibly update its preview, the objects in the viewport remain transparent
Crash got out when I just did a resize of the LV window
The problem with freezing Cinema4d and VDB and particles disappeared which was in RC6.1.
There is no information about these fixes. (take an example log fixes from RS)
here is the "final release v5")
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
bagel
natemac00 wrote:In SpotLight - "Camera visibility" shouldn't that also control if the barndoors are visible, or how do you hide those?
Also why is there a shadow in the middle of the spotlight beam?
The attachment Screen Shot 2019-03-19 at 5.11.05 PM.jpg is no longer available
It's in the Light Settings tab of the octane light tag.
bagel
Aoktar,
Is there any method for controlling the distance of the scatter medium in the spectron light? I figured out how to control the angle (apparently a function of the cone angle in the details tab for those wondering but it's not exact at all).
Have you created any documentation on how to work with this object in Cinema 4D? Thanks for all your hard work!
tim_grove
Is this release considered stable or release candidate? Please update the title.
natemac00
I want to use them, I just don't want to see them. Aoktar answered this in a later post.
aoktar wrote:I'll implement visibility options on next build. It's coming from medium, play with density and power.
______________
Nate Mac - Chicago, IL
Cinema 4D R26.107 | Octane 2021.1.6
Main: AMD ThreadRipper | Win10 | 32-core | 128GB | RTX A5000 & GTX 2070 SUPER
Slaves: 4x GTX 980 Ti | GTX 1080 | GTX 1070 | GTX 1070Ti
drmaddogs2
Wonders never cease as the Render develops, to including what will happen as to Octane Ray tracing with the upcoming new drivers supposed to enable Ray tracing' in in GTX cards supposedly due out in April according to Nvidia. Likely others that are considering new RTX cards due to pricing and Cuda core counts, have similar wonders when it comes to Octane Render Ray Tracing and how the quality and time rendering will be seen. I wonder if Nvidia has released any Drivers' of that sort to OTOY in preparation for said April release.
ArnoP
Can anyone confirm me NVlink is working with 2 X 2080ti ? I have loaded a heavy scene and no NVlink features seem to kick in ? Where is the magic button ? I have activated SLI in NVIDIA control panel and updated to the latest driver but the liveviewer from C4D is not showing any extra info, nor the render log. help.
3dworks
is this version already supposed to work with the "All Access" Subscription? I cannot get it licensed, tried both Studio and Enterprise versions of the plugin. OSX 10.12.13 here with C4D prime 20.057.
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
Return to “Releases”
