Are you using object tag? Attach a screenshot to show what you doing.divasoft wrote:This version not work with cinema Volume builder. I start render and nothing happens. VDB Volume object does not work same.
Cinema 4D version 2018.1-RC6.1 (Test version)
I recorded short video for you, please watch.aoktar wrote:Are you using object tag? Attach a screenshot to show what you doing.divasoft wrote:This version not work with cinema Volume builder. I start render and nothing happens. VDB Volume object does not work same.
in 4.02 version volume builder works incorrect, but it works.
if i add vdb loader the same thing happens.
https://drive.google.com/open?id=1buXP7 ... 6R084AHbjm
I am also crashing when using either VDB loader or Volume Generator. Either I get a bugreport (no octane error) or will freeze forever and not respond.
I attached a zip with both the bugreport, scene file, and vdb file I am trying to load (though again it also crashes as soon as I create an octane volume generator object also).
This same scene works fine my previous octane version 4.0.2.1
- Volume_Crashing.zip
 - (1.62 MiB) Downloaded 303 times
I have a problem with the 2018.1 RC6.1 Release on my Mac System
OctaneRender 2018.1 RC6 (5000007)
ORC user subscription status could not be retrieved: The server returned a client-side error with HTTP code: 401
ORC subscription status cannot be found
CUDA error 715 on device 0: an illegal instruction was encountered
-> kernel execution failed(kernel0)
-> failed to deallocate device memory
-> could not get memory info
The Versions are:
C4D R20.057 (Build RB269127)
Octane 2018.1 RC6.1
CUDA Driver Version: 418.105
NVIDIA Web driver: 387.10.10.10.40.122
MAC OS: 10.13.6 (17G5019)
The Versions are:
Octane 2018.1 RC6.1
Do you test your octane builds at all? Have you ever hired a tester?aoktar wrote:Are you using object tag? Attach a screenshot to show what you doing.divasoft wrote:This version not work with cinema Volume builder. I start render and nothing happens. VDB Volume object does not work same.
I do it by myself. What's the problem with having test builds. You don't have to give feedbacks.divasoft wrote: Do you test your octane builds at all? Have you ever hired a tester?
yes, R6.1 constantly freezes C4D 20.057 on particles, VDB.Studio21 wrote:Got instant crashes using X-particles with this version. RC4 works fine. can anyone confirm?
this is a very unstable release.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
You need to downgrade to CUDA 410.130:st3ncil wrote:I have a problem with the 2018.1 RC6.1 Release on my Mac System
The Versions are:
Octane 2018.1 RC6.1
https://www.nvidia.com/object/macosx-cu ... river.html
and probably also to the following GPU drivers:
https://www.nvidia.com/download/driverR ... 2147/en-us
ciao Beppe
