OctaneRender™ 2018.1 RC6
Notiusweb
I now tested Bench 2019 with my 8 Titan X (1 maxwell, 1 Xp, and 6 Pascal), and got 1265.
And...someone got 1298 with 2x 2070 Ti RTX... (in mode "RTX-On")
To me the short and sweet is this....
You will have the same render time as you see now for your scenes, but instead of at the benchmark resolution, you will have that at 1080p.
In other words, if you want to, with a non-RTX card, ball-park simulate what it would be like to have all your cards at RTX speed for a 1080p-ish scene, set resolution at benchmark's 933 x 560.
You can essentially cut the resolution of your scene in half. Whatever speed you get, that is ballpark your card would get on your scene with RTX!!!!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
funk
I filed a visibility bug in the octane 4 thread but it also affects 2018.
Files are attached here:
viewtopic.php?p=358457#p358457
pixym
When could I see the "Anime kernel" ?
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
PolderAnimation
PolderAnimation wrote:I believe when there are more then 5 grayscale vertex attributes the 6th does not work. Is this correct? or is this a bug?
please
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
funk
Ive tried rendering out a few different scenes using cryptomatte (to layered 32 bit EXR).
I've tried the last couple of cryptomatte releases https://github.com/Psyop/Cryptomatte (1.2.3 and 1.2.4), and the reactor version https://www.steakunderwater.com/wesuckl ... =32&t=1775 in fusion 9 https://www.blackmagicdesign.com/au/products/fusion/ .
Every time I select the CryptoInstanceID layer, the script breaks. All the other cryptomatte passes are working fine. V-rays cryptomatte passes also work fine.
There seems to be some issue with the Octane CryptoInstanceID pass.
Maybe this fusion error will give you guys a clue?
...agic Design\Fusion\Modules\Lua\cryptomatte_utilities.lua:846: manifest string is empty or nil
stack traceback:
	[C]: in function 'assert'
	...agic Design\Fusion\Modules\Lua\cryptomatte_utilities.lua:846: in function 'load_manifest'
	...agic Design\Fusion\Modules\Lua\cryptomatte_utilities.lua:731: in function 'initialize'
	...agic Design\Fusion\Modules\Lua\cryptomatte_utilities.lua:912: in function 'create_cryptomatte_info'
	...ng\Blackmagic Design\Fusion\Fuses\Matte\cryptomatte.fuse:583: in function <...ng\Blackmagic Design\Fusion\Fuses\Matte\cryptomatte.fuse:568>
Cryptomatte3 failed at time 0
J.C
funk wrote:
If I use the "veTcron (typo) shadertoy primitive" example and apply a universal material, some faces render black.
Happens in many flat surfaces.
Looks like Universal material bug. In previous release RC4 it was ok.
System – Windows 11
divasoft
Hi, adding portals to the scene significantly increases the noise. Did you plan it this way or is this another flaw?
Cinema 4d integration.
HHbomb
As the two renders are almost identical except noise, why do you use portals ?
Despot
HHbomb wrote:As the two renders are almost identical except noise, why do you use portals ?
I saw this guys post the other day and thought the very same thing... those renders are almost identical, the area near the central hanging lamp is slightly brighter, that's all to my eyes.
Perhaps he is using them incorrectly.
haze
please
Currently the maximum number of greyscale attributes is 4, and the maximum number of color attributes is 2. We limit this so that it doesn't affect performance too much
