Do I miss something or is there a "in between node" already?
This should not be hard, but very convenient.
benefits
-no separate osl files (if unlinked)
-max internal script editor
tnx
boris
3ds Max 2019 Native OSL Interface support
- paride4331
tnx Paride but I am not sure you understand:
I know can use Octane OSL Texture with a file.
But take a look at the functionality of the 3dsmax Node. It's good because you can edit the osl if you want and then it will be stored in the Max file.
Would be nice to be able to connect that (similar like the developpers made the link to the 3dsmax image map texture).
This can't be hard.
It's a feature new in 3ds max 2019 .
cheers
boris
edit: to better understand:
https://help.autodesk.com/view/3DSMAX/2 ... g_osl_html
This can't be hard.
cheers
boris
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder
- paride4331
Hi Boris,
mouse rightclick on .osl in Octane OSL slot.
Is it possible to use max OSL object projection in octane?
- paride4331
Hi tcheng00,
no it's not, not all max osl work with Octane OSL.
paride4331 wrote:Hi tcheng00,
Thank you. It's good to know.
