OctaneRender® for 3ds max® v2018.1-RC4 - 7.03 [TEST]
paride4331
coilbook wrote:Looks like setting gamma to 1 in the material editor helped but now i have two problems:
1. Making the sky bright makes area around the sun almost white. Anyway to fix this and reduce just sun intensity and make blue sky brighter?
2 Border mode still doesn't work.
And why do I have to set Gamma to 1 to begin with?
Hi coilbook,
Octane seems work fine, your hdri has not a good dynamic range setting.
HDRI have to set 1, linear range is from 0 to 1.
https://www.cg.tuwien.ac.at/research/pu ... 6-HDR-.pdf
SergKlyosov
Can we update Nvidia drivers with this release of Octane?
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
paride4331
SergKlyosov wrote:Can we update Nvidia drivers with this release of Octane?
Hi SergKlyosov,
Yes, you can; latest Nvidia drivers works with v2018.1 RCx and 4.02.1 but not with 4.01.1.
coilbook
Hi coilbook,
Thanks Paride,
Could you tell me how to adjust the sky and the Sun brightness separately. Do I use this HDR dialog? And if yes what do I need to change. Do you have a sample scene by any chance with HDR map I sent you
Thank you!
mbetke
i think the HDR load settings have no affect when using Octane as a renderer.
PURE3D Visualisierungen
mbetke
The slowdowns during work seem indeed realated to the plugin. The more I use the material editor the slower 3dsmax gets. Noticed yesterday during conversion and editing a lot of materials.
Will there be improvements soon?
HHbomb
is there network rendering with 2018.1 rc4 ?
paride4331
HHbomb wrote:is there network rendering with 2018.1 rc4 ?
Hi HHbomb,
Enterprise license only.
coilbook
mbetke wrote:The slowdowns during work seem indeed realated to the plugin. The more I use the material editor the slower 3dsmax gets. Noticed yesterday during conversion and editing a lot of materials.
same here. When editing mesh/modeling and then using octane viewport slow down gets worse and worse and 3ds max must be restarted. Please look into it, otoy
coilbook
Hi Pairde,
Could you give an advice on HDR Sky. In RC7 version I never had this problem with the Sun being too bright
Return to “Releases”
