1. Octane's slow materials and making 3ds max run slow after using octane viewport for a while is still not fixed. 2 videos attached, it happens a lot when you work with textures after octane viewport was opened. Thanks
2. HDR skies are now very dark but the sun is too bright Do i need to change anything? RC7 never had this problem
OctaneRender® for 3ds max® v2018.1-RC4 - 7.03 [TEST]
- slow max.MOV
- (2.12 MiB) Downloaded 2624 times
- bad perf.MOV
- (2.82 MiB) Downloaded 2607 times
..I think those slowdowns after working for a longer time is down to max, I've read complaints like that on other groups as well, hope there's somthing to be done, but a restart of max is a stupid solution.. I think I always had them ..
On other note, I'm using this version for production, and so far it's not terrible, crashes when I do some complex operations like pathdeform while messing with a stack.. so I'd say not bad so far - I'm apparently using every test version as production, as it's the best way to test (not gonna complain if it screws me up)
3dmax, zbrush, UE
//Behance profile //BOONAR
BTW xref doesn't really refresh the materials apparently. .
Also this common max scaling issue: what system units should I use really - I've go it set on 1 unit 1 cm.. and I mean it's fine, I know octane uses 1m as 1 unit, but shouldn't it translate something internally so that new users don't get confused ..
I'm doing a product render shot with 1 unit 1cm and in cm, and now I'm starting a landscape arch, which should really be in meters, but it actually seems to tiny when I switch everything to 1m, when I'm working with tiny stuff I get some camera view issues, clipping etc,,
Is it ok to work with defaults for all cm and 1 unit 1 cm ..
3dmax, zbrush, UE
acc24ex wrote:..I think those slowdowns after working for a longer time is down to max, I've read complaints like that on other groups as well, hope there's somthing to be done, but a restart of max is a stupid solution.. I think I always had them ..
Thank you
- paride4331
coilbook wrote:1. Octane's slow materials and making 3ds max run slow after using octane viewport for a while is still not fixed. 2 videos attached, it happens a lot when you work with textures after octane viewport was opened. Thanks
Hi coilbook,
hdri seems ok, I tested 6.14, RC3 and RC4, coulf you check if you changed something in LUT or Gamma?
I found some freezing using HDRIs in RC4, sent it to developers.
Yes, 3dsMax material editor goes slowly, I hoped in new Nvidia drivers, but nothing.
- paride4331
Hi acc24ex,acc24ex wrote:BTW xref doesn't really refresh the materials apparently. .
It doesn't depend on Octane, set 3dsMax system unit before starting to work, switching on fly from 1u=1cm to 1=1mt you you will incur on unit of measurement issue.
paride4331 wrote:coilbook wrote:1. Octane's slow materials and making 3ds max run slow after using octane viewport for a while is still not fixed. 2 videos attached, it happens a lot when you work with textures after octane viewport was opened. Thanks
Hi coilbook,
Hi paride,
I am using 4.02.1 6.14 I sent you HDR map as PM Can you try it? I am not sure what I am doing wrong. it's just dark
My scene also has enable gamma and lut disabled
Looks like setting gamma to 1 in the material editor helped but now i have two problems:
1. Making the sky bright makes area around the sun almost white. Anyway to fix this and reduce just sun intensity and make blue sky brighter?
2 Border mode still doesn't work.
And why do I have to set Gamma to 1 to begin with?
- senorpablo
Generally speaking, 1 is the correct gamma for all maps except diffuse textures that are based on photos. Definitely HDR image formats(exr, hdr) expect gamma 1.coilbook wrote:Looks like setting gamma to 1 in the material editor helped but now i have two problems:
Why Otoy decided to have gamma default to 2.2 is beyond me. It's not correct and demonstrates a lack of understanding of the field.
Under the hood is kind of a mess. The displacement maps, and probably many others, internal to Octane have some goofy, non-linear math going on.
