Cinema 4D version 4.02.1-R3 (Obsolete stable)
donantonio99 wrote:
You can see more details in render log. See CONSOLE window and post all text here.
Where is it? I see Octane Log, its empty, only these 2 lines
Started logging on 22.02.19 11:02:28
OctaneRender Studio 4.02.1 (4020100)
PS - I run GPU-Z, and it says PerfCap Vrel with the blue filling.. I guess its something about that..
I'm saying Console window not octane log. In Mainmenu/script/console
miohn
Hi Ahmet,
don't know, if this was mentioned before, but here with the latest version
(...R3) image in LV gets blurred sometimes without any reason.
regards
Mike
thanulee
Heya, when converting a glossy material to sub material, roughness float slider doesnt work unless u put a float texture.
donantonio99
aoktar wrote:
Ok, Ahmet!
new 2.txt
(10.19 KiB) Downloaded 309 times
Domenicozzo
Hi Ahmet,
I've noticed a difference between 4.02.1 and 4.02.1-R3 regarding the Voxel Particle Rendering via the Object Tag when applied to a Volume Builder in R20: previously I was able to get a proper volume through it, now with the latest release it seems something has changed about that? I can't get it anymore the same volume I had with the 4.02.1
Thank you,
Domenico
donantonio99
I am sorry, but is there any luck with my problem? :cry:
divasoft
Hi Ahmet, how i can fix issue with displacements holes?
donantonio99 wrote:I am sorry, but is there any luck with my problem? :cry:
I'm gonna test it. It was weekend.
Kretschi
Hello,
Great version! Thanks.
But something strange happens.
I can't render with the Render Queue because of a missing file error.
When I open the Cinema Texture Manager I see a missing image: Octane_Gear.png with a strange path.
I can not delete it but I replace it with an image on my harddrive (which the same name)
Everything looks fine, but when I ad the scene to the Render Queue I get the same error en the missing image is back in the Texture manager... ??
Best regards, Andreas.
Schermafbeelding 2019-02-25 om 19.35.28.jpg (11.23 KiB) Viewed 4878 times
Schermafbeelding 2019-02-25 om 19.28.09.jpg (14.3 KiB) Viewed 4878 times
Kretschi
Sorry, I found the problem...
I deleted the xpresso tag from a octane spotlight (I think some free spotlight rig..) and everything works fine...
Return to “Releases”
