Volume Pass and Alpha Behavior
joeycamacho
Hey Ahmet,
I've been trying to export out a separate volume pass with other light passes.
When the medium/fog is activated activated in the environment tag, the light passes and their alphas become slightly transparent where the solid object is, and the background where there are no objects become more opaque.
This also occurs on the main pass, but not the diffuse or reflection passes
Is this the correct behavior?
I'm probably missing something, but compositing these in AE is not providing the same result as the picture viewer.
I've attached some screenshots and a scene file. Please let me know if I've overlooked something.
Thank you!
volume_pass_test.zip
(6.32 MiB) Downloaded 252 times
Freelance Motion & Graphic Designer
Cinema 4D R19| Win 10 Home 1803 | 4X GTX TitanX 12GB Maxwell | Intel Core i7 5930K 3.5GHz | 48 GB DDR4 -2133 RAM
joeycamacho
Giving this a bump... Does anyone else know? Seems like devs are pretty busy!
joeycamacho
BUMP.
Dev is on holiday for a while. I'll try to help but possibly nothing about plugin side.
joeycamacho
Sorry Ahmet - does that mean you can help?
joeycamacho
Hey Ahmet - could you please take a look at this - I'm guessing the devs that were on holidays are back now. Hopefully.
tschwenke
Anyone?
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
What's your version? I suppose that's fine on latest builds.
JEEK
@aoktar
Still having the same issue on 4.02.1-R2 here.
