Hey guys, I need a bit of help troubleshooting. I`m currently working on retexturing the Nissan Fairlady model made by the Szymon Kubicki, however when I tried to load the tire displacement into my material the entire plugin crashes. I tried with other displacement like an 8K Jsplacement map and with that it works fine. I work with C4D and I have the latest release V4.02 - R3. I`ve tried going back couple of releases, but loading this image into the displacement will crash the plugin instantly, no matter the version. I have tried to export it at lower res, export it as .jpg instead of .png and it doesn`t matter....
I have attached the node structure of the material and the bug report that gets saved to the C4D preferences folder.
Your help is greatly appriciated.
Many thanks
Crashing instantly on discplacement.
C. RAM Capacity (i.e. 6 GB)
- laszlosomogyi
- _BugReport.txt
- The bug report that gets saved upon crash
- (360.04 KiB) Downloaded 212 times
Bugreport seems like coming from a 2018.1 build, isn't? What's up if you use a smaller image and lower level of displacement? Also you should send a sample scene and better information as we wrote at top for bugreports.
