OctaneRender 4 for Rhino (OBSOLETE)
Forums: OctaneRender 4 for Rhino (OBSOLETE)
Re: OctaneRender 4 for Rhino (TEST and STABLE)
Postby Refracty » Wed Feb 13, 2019 8:42 am
Refracty Wed Feb 13, 2019 8:42 am
Paul, you are the best !
Thank you so much
Refracty
Postby Bendbox » Wed Feb 13, 2019 7:01 pm
Bendbox Wed Feb 13, 2019 7:01 pm
Hi Paul,
So glad we have our material previews back!!! Thanks for this update!
I did notice one bug, but not sure if it's Octane or Rhino -- when right clicking on a material, none of the options are selectable from the menu that pulls up.
Ryan
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
Bendbox
Postby face_off » Thu Feb 14, 2019 12:14 am
face_off Thu Feb 14, 2019 12:14 am
This was an attempt to get the Copy/Paste menu to appear, but it looks like it is not working. I will get back to McNeel of this.
Postby face_off » Tue Feb 19, 2019 3:11 am
face_off Tue Feb 19, 2019 3:11 am
I have posted a TEST release of the plugin at the top of this thread as follows:
2018.1.0.105
- Compiled with Octane 2018.1 RC4
- Implements the new Render Passes Cryptomatte functions from Octane 2018.1
- Does not implement the new Vectron, Volumetric Spotlight or Vertex Attributes from Octane 2018.1. Vectrons can be used by loading an ORBX file containing a Vectron node.
Postby Refracty » Thu Feb 21, 2019 8:01 pm
Refracty Thu Feb 21, 2019 8:01 pm
Copy and Paste of nodes is so important - Hopefully it can be fixed
Refracty
Postby face_off » Thu Feb 21, 2019 9:59 pm
face_off Thu Feb 21, 2019 9:59 pm
McNeel have indicated this is fixed in the final release of SR14 for Rhino6.
Postby Refracty » Fri Feb 22, 2019 8:22 am
Refracty Fri Feb 22, 2019 8:22 am
Perfect
Thanks for the info Paul
Refracty
Postby Bendbox » Fri Feb 22, 2019 1:23 pm
Bendbox Fri Feb 22, 2019 1:23 pm
Awesome, thanks Paul
Ryan
Bendbox
Postby face_off » Mon Mar 18, 2019 2:12 am
face_off Mon Mar 18, 2019 2:12 am
I have posted the next Octane 2018.1 build at https://render.otoy.com/forum/viewtopic.php?f=41&t=71037. If there are future Octane 4 builds, they will still be posted in this thread.
Postby face_off » Tue Apr 30, 2019 11:36 am
face_off Tue Apr 30, 2019 11:36 am
I have updated the installers at the top of this thread with:
4.04.0.107
- Compiled with Octane 2018.1.1
- Fixed crash when loading the plugin with the Material tab selected
- Fixed issue where Texture Mapping changes for meshes where Live Update enabled where not being live updated in the Octane Viewport
- Fixed issue where an incorrect message appeared if you tried to use the Rhino Render->Render menu option to render when you had not yet opening the plugin Setup panel
PreviousNext
Return to Rhinoceros 3D
Tue Jun 04, 2024 3:25 pm [ UTC ]
